93 dx slight miss
Old May 4, 2008 | 12:10 PM
jimmy o.'s Avatar
Default 93 dx slight miss
Ok this car is really testing my patience this is a recurring nightmare ive replaced o2 sensor, fuel filter, plugs, Iacv, throttle body, i even took out the cat . What could be my problem if cant figure this out soon im going to sell it or beat the hell out of it till i blow this crappy d15. any imput is appreciated thanks
Old May 4, 2008 | 12:20 PM
Dasfinc's Avatar
Default Re: 93 dx slight miss (jimmy o.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. &raquo;</TD></TR><TR><TD CLASS="quote">Ok this car is really testing my patience this is a recurring nightmare ive replaced o2 sensor, fuel filter, plugs, Iacv, throttle body, i even took out the cat . What could be my problem if cant figure this out soon im going to sell it or beat the hell out of it till i blow this crappy d15. any imput is appreciated thanks</TD></TR></TABLE>
... Have you replaced the Plug wires, Dizzy cap or rotor.... Those are all cheap parts that go bad and would cause a miss..... I dunno why you replaced the throttle body though, thats a bit random, the TPS is the only thing that goes 'bad' on it...
Old May 4, 2008 | 12:35 PM
jimmy o.'s Avatar
the trottle body was tamped with and as for the the ignition i know almost everthing in the dizzy was changed cap, rotor, icm, coil sorry for not listing these they were replaced by the previous owner it used to have a problem before i bought it th idle would go up to about 3k then go back down and do it repeatedly while driving i dont know about the wires they look ok but what the specified resistance through them??
Old May 4, 2008 | 12:37 PM
wonder squirrel's Avatar
Default Re: (jimmy o.)
8-10k ohms per foot is usually a good rule of measure for plug wires.
Old May 4, 2008 | 12:54 PM
jimmy o.'s Avatar
thanks i will check them now
Old May 4, 2008 | 01:13 PM
jimmy o.'s Avatar
all wire came back between 8-12K ohms which means there ok what else can i check could the set screw be loose on the cap??
Old May 4, 2008 | 01:21 PM
Dasfinc's Avatar
Check your ignition timing is the next thing I'd do.
Old May 4, 2008 | 01:23 PM
jimmy o.'s Avatar
had it checked its fine
Old May 4, 2008 | 01:58 PM
jimmy o.'s Avatar
I think i found the source of the problem one wire going to the icm was not connected properly the connector was merely sitin on top off the little tang on the icm i reconnected it correctly could this have been it
Old May 4, 2008 | 02:50 PM
jimmy o.'s Avatar
still runs like crap this is by far the worst excuse for a honda ive ever owned. also noticed alot of wires insulation splitting
Nick Cello
Jun 13, 2013 05:11 PM
Mattthepartyboy
Jun 7, 2012 02:25 PM
MidwestCartel
May 9, 2007 11:14 AM
Bustinvtec
May 28, 2006 11:16 PM
drummr6
Sep 2, 2005 05:19 PM
