Need someone to double check these bearing clearances
I just need someone to give me some criticism on whether or not these are good choices for bearing sizes.
Block is a b18A and redoing bearings for rods and main caps.
here are the mains
1.
-clearance .0015in
-bearing width = 2.06mm (top), 2.05mm (bottom)
-going with Brown bearing
2.
-clearance .0015in -.002in.
-width 2.03mm(top) - 2.04mm(bottom)
-going with green or brown?
3.
-clearance .0015in.
-width 2.0mm (top) - 2.05 (bottom)
4.
-.0015 in. clearance
-width 2.03mm (top) - 2.05mm (botom)
-going with green
5.
-clearance .0015
- width 2.01mm - 2.03mm
-going with green
any help would be appreciated
here are the mains
1.
-clearance .0015in
2.
3.
-clearance .0015in.
4.
-going with green
5.
-clearance .0015
-going with green
