ARP head studs for Ls motor question- yes I searched first!
Old May 4, 2008 | 11:36 AM
spluvs2install's Avatar
Default ARP head studs for Ls motor question- yes I searched first!
I am doing an ls/vtec swap and when removing the head from a B16 motor, I took out the ARP head studs, as I plan to relocate them to the LS block. I just first need to make sure they will fit correctly and secondly, Do I torque the studs first with an alan key- then tighten down the nut on the top? And if so, what do I torque the nut to? I'm pretty confused as I never have done a head stud WITH nut before.
Old May 5, 2008 | 06:46 AM
bump up for info
Old May 5, 2008 | 06:56 AM
LoseRPunKx182's Avatar
Default Re: (spluvs2install)
snug the stud on hand tight and than torque the nut down. oh and i dont think the b16 head studs will work for your ls block/ls vtec.
Modified by LoseRPunKx182 at 11:06 AM 5/5/2008
Old May 9, 2008 | 12:24 AM
skinyas23's Avatar
for headstuds you should use the b16a's or gsr ones if im correct oem or arp
austinwasthere
12
Jan 19, 2012 12:23 PM
AJxr
Mar 2, 2009 10:21 AM
almostjdmeg
Jan 3, 2009 07:41 AM
90Rexx
Mar 8, 2008 09:24 AM
See Are X
Oct 10, 2005 07:13 AM
