ZC cam in D16A6?
Old May 4, 2008 | 11:15 AM
davidrb's Avatar
Default ZC cam in D16A6?
I have an 89 Si I am building for circle track and I want some extra power. The car has to remain stock for the most part. I am thinking a ZC cam would help a little though. Can I put this in and get some extra power? I have searched but all I can find are ZC - D16 debates. I also think I am gonna get a chipped PM6 to go with it and replace the head gasket with an MLS gasket. TIA
Old May 4, 2008 | 11:18 AM
SIred91's Avatar
Rainman
Default Re: ZC cam in D16A6? (davidrb)
Not worth the work IMO, a header would be better.
Old May 4, 2008 | 11:21 AM
kowcain's Avatar
wouldnt that be agasint the rules for having a pretty much stock car?
Old May 4, 2008 | 12:47 PM
MonkeyMagic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidrb &raquo;</TD></TR><TR><TD CLASS="quote">I have an 89 Si I am building for circle track and I want some extra power. The car has to remain stock for the most part. I am thinking a ZC cam would help a little though. Can I put this in and get some extra power? I have searched but all I can find are ZC - D16 debates. I also think I am gonna get a chipped PM6 to go with it and replace the head gasket with an MLS gasket. TIA </TD></TR></TABLE>
YES.. sohc zc cam will work, and is slightly more aggresive. you can even use dohc zc or usdm d16a9 (old assed integra) pistons for even more compression
Old May 4, 2008 | 01:37 PM
zccr-xsi's Avatar
Default Re: ZC cam in D16A6? (MonkeyMagic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic &raquo;</TD></TR><TR><TD CLASS="quote">
u cant use DOHC zc cams or a1 cams in a sohc a6.
Old May 4, 2008 | 01:44 PM
SIred91's Avatar
Rainman
Default Re: ZC cam in D16A6? (zccr-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">
u cant use DOHC zc cams or a1 cams in a sohc a6. </TD></TR></TABLE>
He said pistons brah.......
Old May 4, 2008 | 02:02 PM
zccr-xsi's Avatar
Default Re: ZC cam in D16A6? (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
He said pistons brah....... </TD></TR></TABLE>
**** i didnt catch the piston part!my bad
Old May 4, 2008 | 06:57 PM
Noahk's Avatar
The cams are the same. The sohc ZC makes more power from the ecu tune and higher octane in Japan. A while back someone measured them and the profiles were the same.
Old May 4, 2008 | 08:29 PM
Tyson's Avatar
Default Re: ZC cam in D16A6? (Noahk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noahk &raquo;</TD></TR><TR><TD CLASS="quote">The cams are the same. The sohc ZC makes more power from the ecu tune and higher octane in Japan. A while back someone measured them and the profiles were the same. </TD></TR></TABLE>
sorry brah, the cams are different. i measured them. do you believe me?
and it depends on if you get the carbed version, or the mpfi. you want the mpfi.
but really, the difference is so slight. its no comparison to an aftermarket cam.
Old May 5, 2008 | 02:56 AM
davidrb's Avatar
Default Re: ZC cam in D16A6? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
but really, the difference is so slight. its no comparison to an aftermarket cam. </TD></TR></TABLE>
Any recommendations on an aftermarket cam? Something pretty close to stock. I really appreciate all the quick answers guys
Old May 5, 2008 | 06:37 PM
zccr-xsi's Avatar
Any recommendations on an aftermarket cam? Something pretty close to stock. I really appreciate all the quick answers guys </TD></TR></TABLE>
well u can always find a stock a6 cam in the junk yard and send it off and get it regrind.
Old May 5, 2008 | 09:04 PM
SoCal B18b 4dr's Avatar
but doesnt a regrind only change the where the "power band" is? u cant add lift when removing material, so is a regrind gonna add power or just move it in the rpm range? ive never owned a regrind am im curious what u get out of it, ive heard alot of stuff about them that didnt seem logical.
Old May 6, 2008 | 01:57 AM
esteen2's Avatar
Default Re: (SoCal B18b 4dr)
You can add lift, but you lose base circle. Try talking to Web Camshafts or Bisimoto.
Old May 7, 2008 | 09:16 PM
Noahk's Avatar
No kidding? I could have sworn someone measured and they were the same. But I will certainly take your word on it!
charlieboyhonda
Jul 22, 2009 05:36 PM
gnccracer20
25
Feb 11, 2009 01:23 PM
autowrench07
11
Sep 27, 2008 06:31 PM
VegaS10
Jun 21, 2005 03:46 AM
dc5mikeydc5
May 4, 2005 07:19 PM
