Rebuilding the old D16: A couple of Q's
Old May 4, 2008 | 06:13 AM
TrashedCrx's Avatar
Default Rebuilding the old D16: A couple of Q's
The car is an 89 Crx, thoroughly trashed by my younger brother. I recently acquired it and plan to rebuild. I'm going the cheap route mainly because I have some good machine shop hookups. So I plan to rebuild the D16, bore it out, oversize pistons, and possibly shave the head a bit. My questions are, the largest pistons I found in a kit (for a reasonable price) are .040 over. Is that safe for a daily driver? I don't want to sacrifice the integrity of the block. Also, can you shave the head? If so how much can you go without treating a piston/valve high speed collision? And can you easily compensate for the timing with distributor tweaking? Any help will be greatly appreciated.
Edit: I have rebuilt Honda and Toyota engines before but just stock for stock. So this is my first "performance" engine build.
Balor_Gr
Apr 4, 2016 02:53 AM
ahenscheid
Feb 3, 2012 11:09 PM
tony7626
Aug 29, 2011 10:43 PM
rangerxtrn
Mar 24, 2008 10:57 AM
