PLX M300 integration with S300 question
Old May 4, 2008 | 05:27 AM
blkb18's Avatar
Default PLX M300 integration with S300 question
I am running 96 GSR with JRSC, tuned with a Hondata S300 obd2 socketed p28. I plan to only running the wideband sensor so I need just to connect the white wire to an input. Everyone says to use the ELD input. Does the p28 not have an ELD input? What are the other options in the pull down menu? Thanks.
Old May 4, 2008 | 08:32 PM
phearable's Avatar
Default Re: PLX M300 integration with S300 question (blkb18)
The p28 does have an eld.
Take not that you will have to cut out (remove) 2 resistors & disable the eld function in the parameters section to get the input to function properly.
Read the hondata help file.
Old May 5, 2008 | 05:50 PM
blkb18's Avatar
So I can just keep the ELD as is and choose another input for the a/f sensor.
Old May 8, 2008 | 09:10 AM
ChickenH's Avatar
If you open the software, you can see on the menu your choices for the input,(where the default one says ELD )all the inputs you can use. Make sure the readings of your widebands voltage output or readout gauge match up to what the hondata says its getting when your done. YOU MIGHT HAVE TO CHANGE VOLTAGE OFFSET.
Old May 10, 2008 | 09:08 AM
kevinz's Avatar
Default Re: PLX M300 integration with S300 question (ChickenH)
eld is d10 on the board,remove r136&r138 on the ecu,very easy, even a person from Melwood could do it.
p28 is obd1
http://technet.ff-squad.com/wiring.obd1.htm
Old Nov 29, 2008 | 03:48 PM
luv2boost's Avatar
Thanks!! I forgot to disable eld in options!
EK9345
Engine Management and Tuning
Mar 22, 2011 06:13 AM
Riake
Jan 19, 2005 07:09 AM
sleeping GIANT
Oct 9, 2004 08:27 AM
94si94cx
Nov 3, 2003 09:11 PM
FredoSP
Sep 21, 2003 01:27 PM
