Alarm Help please.
Old May 4, 2008 | 12:04 AM
theeogflip's Avatar
Default Alarm Help please.
I currently installed a pager alarm on my 96 civic, but I have a small problem. My alarm wont disarm when I start the car. For example.. I unlock the door (by remote), start the car, then after a minute (with the engine still on) the alarm goes back on armed mode.. what wire could be wrong? The alarm has remote start feature, but I dont need it since I live in cali and its never freezing here. I have atached my wiring
I thought it might be the door pin trigger since I got an aftermarket radio (disables domelight feature when door is open), but I jumped pin#8 (pin door) to pin#14 (domelight) from the oem green radio harness to get my domelight to turn on when the door is open.
Any advice is greatly appreciated. Thank you. I'm willing to donate $10 (via paypal) to the person who can help me get this right Thanks again.
Old May 4, 2008 | 01:25 AM
john666's Avatar
Default Re: Alarm Help please. (theeogflip)
check the blue wire on the alarm, im guessing u didnt connect that one
Old May 4, 2008 | 05:29 AM
chargedecivic's Avatar
Default Re: Alarm Help please. (john666)
where did you get the door trigger at? u will have to get it right at the pin for it to know the door was open and for it not to rearm.
Old May 4, 2008 | 05:33 AM
Default Re: Alarm Help please. (chargedecivic)
also make sure you hooked an ignition wire up so that when the car is turned on it sends a signal to the alarm. this also resets the alarm if it has been triggered. i cant tell from your diagram which wire is for ign. but make sure that is also hooked up! try that before messing with the door pin
Old May 4, 2008 | 07:52 AM
theeogflip's Avatar
The door pin trigger is connected to the door pin (solid green wire color found at driver side kick panel). Is this the correct wire?
Old May 4, 2008 | 05:30 PM
Default Re: (theeogflip)
best place to get is behind radio in the green alarm plug. it is lt. green/red or found in a light green plug above the fuse box or bottom of driver kick, harness to rear. let me know ill help all i can. ive been doing this for 15 years now so ill whatever i can for you to get you going.
glenn
mickey513
Audio / Security / Video
Mar 12, 2014 03:10 PM
laziebun
11
Jan 23, 2011 04:16 PM
Accord1234
Feb 4, 2008 11:09 PM
alarmguy
Jan 7, 2006 09:08 AM
visualx
Nov 23, 2003 08:43 PM
