B16 starting then dies (sometimes)
Old Jul 13, 2002 | 01:51 PM
FUP23's Avatar
New User
Default B16 starting then dies (sometimes)
Heres my problem...Sometimes it will start then die right away..then after a few times of that ****..it starts up and runs great. Anyone think its the fuel filter ??? I hear the pump and main relay working .... Im throwin a code 2 also9after ive been driven for 30mins or so). Thanks
Old Jul 13, 2002 | 03:37 PM
rice_classic's Avatar
Default Re: B16 starting then dies (Devin17)
code 2 oxygen sensor.. defective connection or plug
code 9 cyp (cylinder) sensor.. defective or bad connection
other than that I can't help
Old Jul 13, 2002 | 05:03 PM
Taloola's Avatar
Default Re: B16 starting then dies (rice_classic)
i had that same problem. couldn't figure it out either
never had a chance to really look into it. b16a rip!!!!!!
Old Jul 13, 2002 | 05:17 PM
USDM 4G VTEC's Avatar
if it trows a code 2 its the O2 sensor,,,,,
go replace the sensor with an universal O2 sensor.. they run for like 35$...
if the ecu doesnt get the right signal it might not get the right fuel /air mixture and thats maybe why it turns off.... replace that O2 and see if it helps....
Old Jul 13, 2002 | 06:18 PM
Hcivic88's Avatar
It says here that its the #1 cylinder position and to check/replace the crank angle sensor
atuvy
Jul 21, 2012 03:50 AM
krkline2gdsm
Jan 28, 2009 11:11 AM
shalemain
Sep 23, 2004 08:07 AM
alberto.garrido
Jul 27, 2004 09:33 AM
delguiner
Jul 8, 2004 08:32 AM
