Partial Hydrolock *Need Help*
Old May 3, 2008 | 08:47 PM
FhCRubarb's Avatar
Default Partial Hydrolock *Need Help*
Yesterday I was driving and ran into a deep puddle. I have been in a similar situation so I knew right away to turn off the motor. After cruising to a stop I unbolted the AEM V2 intake from the intake manifold and sure enough there was water in the intake manifold before the butterfly valve. I got the car running and drove it to work with the intake unbotled no problem. Today however, I was leaving work and the car simply would not start. It would turn over and choke out, turn over and choke out it kept doing this. I finally got it started after doing rolling starts which failed and finally it started by just turning the key and giving it some gas. Now, the car is running like absolute ****, bogging down, stalling etc. When I have it at low rpms and hit the accelerator it is hesitant and not smooth at all. It almosts sounds like a it is misfiring because it is gargling, perhaps a spark plug went bad from water? I have not taken the spark plugs out yet but I am going to tomorrow. Do you guys have any tips for me?
Old May 3, 2008 | 09:19 PM
v8 integra's Avatar
Default Re: Partial Hydrolock *Need Help* (FhCRubarb)
ive herd but not experienced..to leave the car on and idle for like 15-30 mins...sumone shine some light on this!!
Old May 3, 2008 | 09:36 PM
yoffer's Avatar
Banned
Do you have any cel's come on?
I would really check and replace the sparkplugs and see what that does for you.
Old May 3, 2008 | 11:42 PM
obuhmyuh's Avatar
Default Re: (yoffer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8 integra &raquo;</TD></TR><TR><TD CLASS="quote">ive herd but not experienced..to leave the car on and idle for like 15-30 mins...sumone shine some light on this!!</TD></TR></TABLE>
id let the water burn off, but im not an expert...
bummmp
Old May 4, 2008 | 03:39 AM
FhCRubarb's Avatar
Default Re: (obuhmyuh)
I did not throw a CEL even when running the car with no intake connected = no mass air flow sensor working properly
Old May 4, 2008 | 06:02 AM
wonder squirrel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FhCRubarb &raquo;</TD></TR><TR><TD CLASS="quote">Yesterday I was driving and ran into a deep puddle. I have been in a similar situation so I knew right away to turn off the motor. After cruising to a stop I unbolted the AEM V2 intake from the intake manifold and sure enough there was water in the intake manifold before the butterfly valve. I got the car running and drove it to work with the intake unbotled no problem. Today however, I was leaving work and the car simply would not start. It would turn over and choke out, turn over and choke out it kept doing this. I finally got it started after doing rolling starts which failed and finally it started by just turning the key and giving it some gas. Now, the car is running like absolute ****, bogging down, stalling etc. When I have it at low rpms and hit the accelerator it is hesitant and not smooth at all. It almosts sounds like a it is misfiring because it is gargling, perhaps a spark plug went bad from water? I have not taken the spark plugs out yet but I am going to tomorrow. Do you guys have any tips for me?</TD></TR></TABLE>
As far as hydrolocking an engine, its either hydrolocked, or its not, theres not really a in between thing. Yes, you can get water in an engine and still have it die, but its not hydrolocked if you can crank it over and start it. Sounds like you shut it down before it sucked up enough water.
If you drove the car away no problem then you would have flushed out all the water in the engine and likly ALL the carbon built up anywhere in pistons/ combustion chambers as well. If there was damage you would have noticed it immediately.
I'd say your problem lies somewhere else since you drove away. Possibly the idle control valve is gone bad since it got soaked?
Old May 4, 2008 | 06:17 AM
random chaos 85's Avatar
Default Re: (FhCRubarb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FhCRubarb &raquo;</TD></TR><TR><TD CLASS="quote">I did not throw a CEL even when running the car with no intake connected = no mass air flow sensor working properly</TD></TR></TABLE>
since when did honda put mass air flow sensors on civics?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wonder squirrel &raquo;</TD></TR><TR><TD CLASS="quote">
I'd say your problem lies somewhere else since you drove away. Possibly the idle control valve is gone bad since it got soaked?</TD></TR></TABLE>
^ that sounds a little better
Old May 4, 2008 | 06:31 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: (random chaos 85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by random chaos 85 &raquo;</TD></TR><TR><TD CLASS="quote">
since when did honda put mass air flow sensors on civics?</TD></TR></TABLE>
He must mean IAT sensor. IIRC new Civic engines have both MAF and MAP sensors.
ej8love1
Aug 21, 2010 05:19 PM
LilCivic04
Mar 2, 2007 01:31 AM
Ls_V_TurboSi
Jan 30, 2006 03:32 PM
tRex99
Nov 4, 2004 03:58 PM
Diegolude
Apr 5, 2003 04:02 PM
