Topping off transmission fluid...make sure the car is level?
Old May 3, 2008 | 05:49 PM
erikiksaz1's Avatar
Default Topping off transmission fluid...make sure the car is level?
I was thinking of checking my transmission fluid levels, but then I realized something when I went to level out the car.
[Looking from the passenger's side fender]
The top of the valve cover and the bottom of the transmission are not parallel (or level). If I try use the top of the valve cover to level out the car, the bottom line of the transmission angles upward. If I use the bottom line of the transmission, the top of the valve cover angles downward.
Which one should I use as my level for making sure that my tranny fluid is filled optimally?
aaronhume
Feb 11, 2007 10:24 PM
mcgee*
Jun 20, 2005 01:31 PM
vtec.dc2
May 6, 2005 01:40 AM
allmotorhatch
Mar 8, 2005 09:46 AM
