help! increasing rpm when throttle released
Old May 3, 2008 | 04:39 PM
BoostedH's Avatar
Default help! increasing rpm when throttle released
i have a 99 si stock b16. this only happens when driving. if u let off the accelartor
the rpms will continue to increase after accelration. i have a check engine lamp but only stored codes for cat efficiency and my cat is failing so we can rule out any help from that. i have replaced the idle air control motor with one i had on another b series i knew was running correctly. i also swapped ecu just to be sure also. i sprayed intake manifold with throttle cleaner to check for possible intake air leaks and pinched off vaccum lines to brake booster purge volume control soilnoid, ect... still no change in concern. at this point i am alittle unsure where to go from here since nothing is electronicly failing that i can see... the throttle does not physically stick i have checked several times and idle screw has never been
adjusted. the only thing i can maybe think of is that the tps is sending incorrect voltage measurements to ecu. but i really dont know. please hit me up if you have any ideas thank you !!!!
Old May 3, 2008 | 05:35 PM
Former User's Avatar
Default Re: help! increasing rpm when throttle released (BoostedH)
I think the TPS voltage should be 5V fully open and 0.5V fully closed (maybe someone can verify).
Also, have you checked whether the throttle cable may be binding?
Old May 4, 2008 | 01:24 AM
BoostedH's Avatar
Default Re: help! increasing rpm when throttle released (RonJ@HT)
how do you check if it is binding?
Old May 4, 2008 | 10:16 AM
BoostedH's Avatar
TTT
Old May 4, 2008 | 10:22 AM
v!taminb16's Avatar
Default Re: (BoostedH)
or it could aslo be your throttle cable because i went through the same problem i let go of the gas and the rpm went up then down then it idled pretty crazy and all i did ws readjust the cable and i was good no crazy idle
Midori Green's Avatar
have you checked the throttle cable?
Old May 4, 2008 | 10:50 AM
BoostedH's Avatar
throttle cable moves, but how else should i check it?
Old May 5, 2008 | 10:40 AM
BoostedH's Avatar
TTT
Old May 8, 2008 | 10:35 AM
BoostedH's Avatar
BUMP
Old May 14, 2008 | 11:10 AM
BoostedH's Avatar
TTT
Gho$t
Nov 10, 2009 10:26 PM
NiecoJDM
Nov 5, 2009 04:07 AM
HondaEF
Nov 28, 2006 10:46 AM
1baddcivicsi
Mar 13, 2006 08:50 PM
swpdb16
Feb 15, 2003 07:46 PM
