~~~very urgent...orage county~~~~
Old Jul 13, 2002 | 12:30 PM
six_speed's Avatar
Default ~~~very urgent...orage county~~~~
no matter what i do, it wont tighten...the exhaust side is tight, but not the intake side. i did what one member told me, but still it's loose...come and help me please....i'll give you dvds....please.
The tenshion bolts is loosen
then put on the timing belt was put on
turn the crank half way
tighten the tenshion belt
timign belt is loose...someone help~~~~~
or im me here.....
call me 714 373 471...i'm terry......please i need help. asap
[Modified by Lilmumbler, 1:39 PM 7/13/2002]
Old Jul 13, 2002 | 12:50 PM
YeuEmMaiMai's Avatar
Default Re: ~~~very urgent...orage county~~~~ (Lilmumbler)
sounds like the tensioner is stuck ...... try working it back and forth a few times to see if it unsticks
Old Jul 13, 2002 | 01:03 PM
six_speed's Avatar
Default Re: ~~~very urgent...orage county~~~~ (YeuEmMaiMai)
u mean keep doing what i'm doing?
Old Jul 13, 2002 | 03:45 PM
B18C-EJ1
Guest
Posts: n/a
or im me here.....
Set crank at TDC
Set cam gears at TDC
Install belt from exhaust side to intake side
Tighten tensioner by hand until tight
Rotate crank counter clockwise 5-6 times
Stop at TDC
Loosen tensioner 180 degrees
Rotate crank counter clockwise, count 3 teeth on cam gear
Stop
Tighten tensioner to 40ft/lbs
You're done.
Old Jul 13, 2002 | 04:20 PM
six_speed's Avatar
Default Re: ~~~very urgent...orage county~~~~ (B18C-EJ1)
thakyou for the response, if i do this and if one of the side is not tight, it's still good? just start it and find out?
Old Jul 14, 2002 | 06:08 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
do you have a thinner headgasket or shaved head?
Old Jul 14, 2002 | 09:03 AM
six_speed's Avatar
Default Re: ~~~very urgent...orage county~~~~ (rodney)
i think i got it, thanx to MikeSarr_GSR ...
freshCROOKS
Aug 14, 2012 06:38 PM
d16rice
Apr 20, 2005 11:48 AM
six_speed
Jul 13, 2002 11:29 PM
six_speed
Jul 13, 2002 04:17 PM
