My clutch makes a clicking sound
Normal...I have a 2004 civic and it used to make that noise..It also made a noise when down shifting...If this is happening you need to look at getting a new clutch and flywheel. I got the stage 2 exedy clutch and ACT light weight racing flywheel and I have no complaints....It grips great and was the best mod I did to my car other than the custom turbo kit I just put on it..So you might need to look at getting a new clutch and that should fix the problem.
D17a2 @ 8 psi= 214whp
Bitches Love Boost
Bitches Love Boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDURA2K2 »</TD></TR><TR><TD CLASS="quote">It's most likely your clutch master cylinder making the clicking sound. mine is doing the same thing.</TD></TR></TABLE>
Will I damage anything if I still drive the car w/ the clicking sound? Also how much will it cost to get it fix?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vroomboom »</TD></TR><TR><TD CLASS="quote">
You won't damage anything, I drove mine around like that for quite a while and then had it replaced under warranty right before I decided to void mine.
</TD></TR></TABLE>You won't damage anything, I drove mine around like that for quite a while and then had it replaced under warranty right before I decided to void mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katzenjammer84 »</TD></TR><TR><TD CLASS="quote">
Cool, thanks for telling you had the same problem and got it fix, but would help if you told me what did they fix lol
</TD></TR></TABLE>Cool, thanks for telling you had the same problem and got it fix, but would help if you told me what did they fix lol
When I got mine fixed it was the Master cylinder also..So that is what you need to have them fix..but for the price of getting a clutch and flywheel with the tranny already out...you should just look at getting the whole thing like i did..it was the best upgrade for the d17 other than turbo
bbrian
Transmission & Drivetrain
Jun 14, 2013 10:09 AM
SOHC_Brian
Aug 23, 2004 09:58 AM
