stock cam shaft on a built head any problems?
Old May 2, 2008 | 12:34 PM
integra gsr96's Avatar
Default stock cam shaft on a built head any problems?
i was wondering if i can use my stock cam shafts and cam gears on my integra gsr with a built head. would anything happen?
thanks!
Old May 3, 2008 | 04:30 AM
gibsanez's Avatar
Default Re: stock cam shaft on a built head any problems? (integra gsr96)
You wouldn't make as much horsepower as an after market cam.
Old May 3, 2008 | 12:09 PM
Default Re: stock cam shaft on a built head any problems? (gibsanez)
but it would work right?
Old May 3, 2008 | 01:54 PM
gibsanez's Avatar
Why wouldn't it? Does a stock head run fine with stock cams?
Old May 4, 2008 | 07:08 PM
i get where your getting at.
Old May 4, 2008 | 07:09 PM
also i was wondering if you new alot about ecu?
Old May 5, 2008 | 01:41 AM
gibsanez's Avatar
What's your question?
Old May 5, 2008 | 05:31 PM
hondaLovin's Avatar
many people run GSR or ITR cams with built heads for boost applications. Don't see why your's wouldn't work.
Old May 5, 2008 | 07:17 PM
nvm i got everything figured out. thanks anyways ill ask you if i got stuck with any problems thanks alot!
PA MATT
Mar 13, 2007 12:40 PM
DJ Gurgla GSR
Nov 15, 2005 09:14 AM
thehatchninja
Jun 4, 2005 08:28 PM
B18Flip
Jun 2, 2005 12:06 PM
