Suspension & Brakes Theory, alignment, spring rates....
Will your brakes break?
Old May 2, 2008 | 11:55 AM
Civic_07's Avatar
Default Will your brakes break?
Will your brakes break if u dont replace them soon?
Old May 2, 2008 | 01:31 PM
Function7's Avatar
Default Re: Will your brakes break? (Civic_07)
If you dont replace your brake pads before they wear down to the metal backing, the rivets in the metal backing will gouge grooves into your brake disk. The more you drive like that, the worse it gets.
When this happens, it will mean that you will have to replace the damaged brake disks too.
-A
Old May 5, 2008 | 05:35 PM
Colby71's Avatar
If they ware down to much you can hyper extend you caliper/wheel cylinder and you will need to get new ones of those to.
Old May 5, 2008 | 09:31 PM
bsclywilly's Avatar
Congratulations for realizing the difference between the words 'brake' and 'break'. You're one of few on this board to use them correctly, and both in one sentence, wow!
mouab18c1
Suspension & Brakes
Apr 10, 2009 06:53 AM
bobmugen
Mar 21, 2009 12:52 PM
patrickstar
Oct 29, 2007 04:33 PM
Ninja Mike
May 27, 2004 07:20 PM
