patching a flat tire?
Old May 2, 2008 | 08:56 AM
accordinglyevil's Avatar
Default patching a flat tire?
what is the best way to back a flat tire? i know some places use plug while other take the tire off and use rubber cement and apply a piece of rubber over it. so what is the best way to patch a tire?
Old May 2, 2008 | 10:27 AM
japanjay's Avatar
* B A N N E D *
Default Re: patching a flat tire? (accordinglyevil)
Patch on the inside of the tire IMO.
Old May 2, 2008 | 11:06 AM
nsxtasy's Avatar
H-T Order of Merit
The proper way is to take the tire off the rim and apply a combination plug-patch to the inside of the tire. If you don't have a tire mounting machine, take it to a mechanic or a tire shop. I think the tire department at Wal-Mart charges around ten bucks to do this, and I've seen mechanics charge anywhere from $5 to $20.
Old May 2, 2008 | 12:00 PM
PI$TOL's Avatar
* B A N N E D *
Default Re: patching a flat tire? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The proper way is to take the tire off the rim and apply a combination plug-patch to the inside of the tire. If you don't have a tire mounting machine, take it to a mechanic or a tire shop. I think the tire department at Wal-Mart charges around ten bucks to do this, and I've seen mechanics charge anywhere from $5 to $20.
r.wright
Feb 15, 2009 02:03 PM
citrus3000psi
May 26, 2008 08:29 PM
BDogggUT34
Nov 9, 2007 09:15 AM
ck279
17
Feb 6, 2002 07:13 AM
