Where to find Honda 4lug wheels with a LIP
Old May 2, 2008 | 07:34 AM
jwrape's Avatar
Default Where to find Honda 4lug wheels with a LIP
I am about to buy a 88-91 CRX and want a nice wheel with lip. All I find is flat or nearly flat faced wheels. I am looking for the most lip i can fit under the little car. Help a brotha out.
Thanks
Like these
Old May 2, 2008 | 09:20 AM
SuzukaBlueAP2's Avatar
Default Re: Where to find Honda 4lug wheels with a LIP (jwrape)
American Racing Muscle Razor
16" and 17"
4x100 40mm offset
18" ASA JH8
4x100 38mm offset
[img]https://www.tirerack.com/images/wheels/asa/swap/asa_jh8_blk_ci3_l.jpg[.img]
17" ASA AR2
4x100 42mm offset
16" ASA JH6
4x100
42mm offset
They are all on tirerack.com
Old May 2, 2008 | 09:22 AM
jwrape's Avatar
I like #1 and #2. I will check out tire rack
Old May 2, 2008 | 09:31 AM
toyomatt84's Avatar
Sanji
Quite a lot of poor suggestions there, SuzukaBlueAP2. All of them are too tall, for his specific application.
If you're looking for the visual perspective of "deep dish" go with something like Axis OG's or their new 4-spoke model.
PS. The wheels on that specific car are Schmidt Space 1-TLG's. And that car has some serious fender flares.
Old May 2, 2008 | 10:18 AM
jwrape's Avatar
Default Re: (toyomatt84)
Yea, since I posted it i found those German Wheels. Not only are they wide for these cars, they are EXPENSIVE too.
Old May 2, 2008 | 10:44 AM
jwrape's Avatar
I absolutely LOVE the Lip on those wheels and the styles BUT I want something at least 17". 15's are just too small for my tastes. 17's or 18's are what i am looking for.
Any ideas?
Old May 2, 2008 | 10:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">Quite a lot of poor suggestions there, SuzukaBlueAP2. All of them are too tall, for his specific application.</TD></TR></TABLE>
That's what Tire Rack has that fit what he was asking for. Tell them they make poor suggestions.
Modified by SuzukaBlueAP2 at 3:03 PM 5/2/2008
Old May 2, 2008 | 11:02 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwrape &raquo;</TD></TR><TR><TD CLASS="quote">15's are just too small for my tastes. 17's or 18's are what i am looking for.
Any ideas?</TD></TR></TABLE>
You should get a car that uses bigger tires, and has wheel wells and a suspension designed to accept them. Tire availability in 17" and 18" sizes is a problem, because the smallest sizes commonly sold are 205/40-17 and 215/35-18, both of which are MUCH too big for a CRX. You can 18"s with a 2001 or newer Civic, 17"s with an Integra or a '97 or newer Civic. I recommend getting a different car if you like the look of bigger wheels.
Old May 2, 2008 | 11:28 AM
jwrape's Avatar
Default Re: Where to find Honda 4lug wheels with a LIP (nsxtasy)
Do you think a 8.5" wide rim would fit under the car with some stretched rubber, similar to the OG's but .5" wider, with a 35mm offset?
Old May 2, 2008 | 12:53 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwrape &raquo;</TD></TR><TR><TD CLASS="quote">Do you think a 8.5" wide rim would fit under the car with some stretched rubber, similar to the OG's but .5" wider, with a 35mm offset?</TD></TR></TABLE>
NO.
Get some 16x7 wheels, and put 205/40-16 (or 195/45-16) tires on them and they will be perfect for your car. Anything larger than that will be too big. And if you mount the tires on wheels that are too wide, they will be unsafe.
raverx3m
May 12, 2014 06:03 PM
90dxcrx
Mar 25, 2010 04:32 AM
danielfleenor
Aug 24, 2009 07:59 AM
ssm-gd3
Jan 30, 2008 11:18 PM
