No power to fuse box?
Old May 2, 2008 | 06:28 AM
toronto_thunder's Avatar
Default No power to fuse box?
Thats what I was told. Sunroof, pass window both door locks and also heater/ac Will not work??? but the driverside window does work I was told there is no power going to the fuse box?
Anyone know what I need to do fix this or if this is even the problem?
Thanks Ben!!
Old May 2, 2008 | 06:36 AM
hatchling37's Avatar
Default Re: No power to fuse box? (toronto_thunder)
If there was no power, you couldn't start the car. If there was no power, you wouldn't be able to roll down your window. I'm assuming this is a stupid question, but did you check the fuses? Have you gotten under the dash and check the wiring for anything obvious? Have you checked relays? Checked to see if plugs are connected?
oneoffaccord
Dec 29, 2010 09:24 PM
93 Accord-Pom
Nov 2, 2009 11:36 AM
rewerbcrx
Aug 19, 2009 11:03 AM
gaccord00
Nov 9, 2004 08:00 PM
