92 civic overheating.
Old May 2, 2008 | 06:09 AM
krisfnbz's Avatar
Default 92 civic overheating.
It only overheats in idle, never overheats when driving or on the highway going 70.
Car has 90k on the motor, so I will be changing the whole timing belt/waterpump soon... Im about to change the thermo because I believe its getting stuck.
If Im in idle, in park... and I see it start to slowly overheat...if I put my foot on the gas a little and rev the engine....the temperature guage starts to slowly go down.
Im going to change the thermo now, anything else it could be?
Old May 2, 2008 | 07:13 AM
krisfnbz's Avatar
Default Re: 92 civic overheating. (krisfnbz)
Just got done changing the thermo, and kept adding coolant to the radiator while bleeding it, and guess what
Car was on for 20 mins and didnt even BUDGE to overheat! I think I fixed the problem.
But I am not convinced yet 100% because this car wacks out sometimes.
Now I need:
-Timing Belt
-Waterpump
-All belts needed
-Driver side motor mount.
and I need to fix why my car is not starting sometimes.
Old May 2, 2008 | 07:53 AM
ballinboosi's Avatar
ya your thermostat was just getting stuck is all. Cheap fix!
Old May 2, 2008 | 11:56 AM
PI$TOL's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krisfnbz &raquo;</TD></TR><TR><TD CLASS="quote">
and I need to fix why my car is not starting sometimes.</TD></TR></TABLE>
prob the fuel pump relay, my old 92 did it, you can keep turning the key on and off til you here it click on and it starts.
Old May 3, 2008 | 01:57 PM
krisfnbz's Avatar
Default Re: 92 civic overheating. (PI$TOL)
Is the fuel pump relay the same as the main relay under the driver side dash right by the hood latch.
Old May 3, 2008 | 04:06 PM
nonvtec92's Avatar
Was the fan not coming on while you sat at idle?
Old May 3, 2008 | 04:31 PM
ExtremeRice's Avatar
might want to get radiator flushed too... could be poor circulation and make sure the fans coming on...
Old May 3, 2008 | 04:44 PM
krisfnbs's Avatar
Default Re: 92 civic overheating. (ExtremeRice)
yeah the fan was coming on...... so it wasnt the fan.
Old May 3, 2008 | 05:07 PM
Former User's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krisfnbz &raquo;</TD></TR><TR><TD CLASS="quote">Is the fuel pump relay the same as the main relay under the driver side dash right by the hood latch.</TD></TR></TABLE>
yes
Old May 5, 2008 | 04:54 AM
krisfnbs's Avatar
Default Re: 92 civic overheating. (RonJ@HT)
cool thanks!
Old May 5, 2008 | 05:26 AM
PI$TOL's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT &raquo;</TD></TR><TR><TD CLASS="quote">
yes</TD></TR></TABLE>
Old May 17, 2008 | 07:15 PM
krisfnbs's Avatar
Okay so I changed the thermo like 2 weeks ago and today is just started over heating again. I am changing the waterpump this week, along with the timing belt and etc....however...when the car overheats it does the same thing as before. It only overheats in idle, or when I am in traffic moving really slow.
If I am in idle, and it starts to go up... if I rev the engine a little it slowly goes down.
Its either the coolant has bad circulation somehow, water pump, or somethnig really bad like a blown head gasket, or cracked block.
Car has 90k original miles, and is a 1 owner before me.
Errrrr this is a pain!!!
Old May 19, 2008 | 09:25 PM
Default Re: 92 civic overheating. (krisfnbs)
Does the radiator fan run when the engine is hot?
Old May 20, 2008 | 06:30 AM
krisfnbs's Avatar
yeah I think the fans are coming on.
Old May 20, 2008 | 06:46 AM
Hanmin's Avatar
If the radiator fan doesn't turn on, thats your problem, if it is then you will need a new radiator.
Old May 20, 2008 | 08:44 AM
blk92_d16's Avatar
You NEED to know for sure that those fans are running! But I can see how it could be the water pump too. GL!
Old May 20, 2008 | 09:23 AM
krisfnbs's Avatar
typically if I start my car and let it sit in idle from a cold start, about how long does it take for both fans to kick on? What is the sequence so I can check it tomorrow morning. I believe I do have 2 fans.
Old May 20, 2008 | 04:39 PM
Hanmin's Avatar
ones for ac, the otheres for the radiator, check the radiator fins, are most of the fins bent? if so just get a new radiator. just let it sit idle, if your car overheats without the fan turning on once, then its not working properly. If it turns on and still overheats, its the radiator.
Old May 21, 2008 | 07:57 AM
krisfnbs's Avatar
Default Re: (Hanmin)
Okay I will check that out. I just cant imagine that my head gasket or something serious would be blown. Just cant see that from a 90k civic with all original motor 1 owner before me.
Old May 21, 2008 | 08:32 AM
h2392si's Avatar
Default Re: (krisfnbs)
Try the radiator fan swith as well. This happended to me and saved me some $$. If it not working your fan will not come on at the appropriate time. Also make sure the relay is good as well.
Old May 23, 2008 | 06:40 AM
krisfnbs's Avatar
is the fan relay the same as the main relay(under the dash on drivers side), or is that different?
import-tooner
11
Jan 6, 2014 05:28 AM
the_egg
Aug 5, 2010 08:52 AM
Conan
Jan 13, 2010 08:46 AM
krisfnbs
10
Jul 11, 2008 05:39 PM
llevity
Jul 12, 2005 02:39 PM
