cant pass 4k rpms help!
Old May 2, 2008 | 05:15 AM
civichxslow's Avatar
Default cant pass 4k rpms help!
okay here is my problem....i have a 97 civic HX (d16y5) and after driving it for about a good 30mins i wont pass 4k rpms.....for instance, if u hit the gas to pick up speed and it hits 4k it just stops and wont go past it....if u put it in neutral and rev it goes to 4k put just bounces off of it........when i first turn on the car it runs good and everything its just after it warms up i guess that it does this........
oh ya someone told me it does this if ur running low on oil, but my oil is good....so i dunno?
Old May 2, 2008 | 06:47 AM
JDM Lyfestyle's Avatar
Default Re: cant pass 4k rpms help! (civichxslow)
do you have any CELs??
Old May 2, 2008 | 10:04 AM
Default Re: cant pass 4k rpms help! (JDM Lyfestyle)
yep.....and they are for a # of things....like no cat/o2 sensors and what not stuff i havent had for a couple of years already......i searched and read around and found out it could be a # of things so0 ima just go to honda and let my friend run the comp on it see if anything new pops up.
Old May 2, 2008 | 12:32 PM
Juan_Mitosis's Avatar
Its called limp mode. Lowers rev limit, retards timing a WHOLE bunch. She must be smoking a lot, and sounding like a Subaru. Since its OBDII, then yea u need the scanner, no neat pin tricks to get a flashy CEL.
Anyways, Limp mode ( a.k.a. bullshit mode) i some sort of mode the ECU uses to protect itself, but to be functional so you can " limp " home. Fix your CEL's, and it shall go away after resetting the ECU. Good luck!
P.S. Some CEL's cause limp mode, some don't
I suggest u fix first the ones that do. . . which I'm not sure which they are specifically.
Old May 2, 2008 | 05:25 PM
okay well i just got back and they usual stuff poped up......
but i also got some new stuff.....vtec and knock sensor.....there was on old sohc sitting out in the back so0 i got the vtec solenoid off of it....fixed that problem.....now i just need a knock sensor, hopefully that will fix.....
anyways tahnkz.!
MUGEN_EG95
Jun 4, 2009 06:25 AM
bonestock91
Dec 15, 2006 07:01 PM
B18C1 '96 Coupe
27
Jan 26, 2006 02:32 PM
95ex5speed
Oct 20, 2004 12:17 PM
danacixem
Aug 10, 2004 01:13 PM
