Clutch Kit (toda/spoon)
Old Jul 13, 2002 | 10:43 AM
ITRaholic's Avatar
Default Clutch Kit (toda/spoon)
Clutch stuff:
Ok next spring i have to buy new clutch.
i was thinking about Spoon Clutch/cover/flywheel or Toda Clutch Kit(TODA lightweight flywheel, clutch disk, and pressure plate)
im using my car for AutoX but daily driving mostly so what should i consider
the best for me?Also does anyone have any experiense of those 2?
thanks
Old Jul 13, 2002 | 11:11 AM
AJ PwR's Avatar
Default Re: Clutch Kit (RedintegraR)
I don't think you change gears often during Auto-X so by changing clutch won't really benefit you much. Flywheel will make a bit difference cuz of faster revs. I will suggest Spoon cuz it is cheaper than Toda.
Old Jul 13, 2002 | 11:38 AM
mafay2's Avatar
New User
I would go with the Toda flywheel with the Spoon clutch.
Old Jul 13, 2002 | 11:39 AM
ITRaholic's Avatar
Default Re: Clutch Kit (AJ PwR)
well i have to change......
when buying clutch,cover and Flywheel do i need anything else?
Old Jul 13, 2002 | 12:28 PM
type r 01-1063's Avatar
are you doing the install yourself?
Old Jul 13, 2002 | 12:30 PM
ITRaholic's Avatar
Default Re: Clutch Kit (type r 01-1063)
no but i need to get everything needed for that..
Old Jul 13, 2002 | 01:34 PM
AJ PwR's Avatar
The Spoon flywheel comes with flywheel bearing and bolts for the Spoon clutch so the other thing you will need is the release bearing from Acura/Honda dealer.
Old Jul 13, 2002 | 04:40 PM
MugenDC2R's Avatar
I say go for the whole TODA deal because they assemble everything (flywheel, pressure plate, clutch disc). It makes for smoother/safer high rpm use.
Old Jul 13, 2002 | 04:56 PM
Black R's Avatar
25 Year Member
I have the toda clutch and flywheel kit... it's like stock. Pedal is a little stiffer, but honestly, it's not THAT ****** awesome. Holds good for allmotor though.
I got a good deal on it, so I can't complain..... It's made by daikin, like exedy and others are... I think the spoon clutch is about the same honestly, but I have no experience with it. I just know that most of spoon's stuff is a slight upgrade from stock.
Now if I had it to do over again, I'd probably go with something like the cusco setup... that thing is ******* badass! I'm on myself for not getting it!
Old Jul 14, 2002 | 04:43 PM
ITRaholic's Avatar
Default Re: Clutch Kit (Black R)
thanks guys H-T OwnZ...
volkracing99
11
Jul 21, 2002 09:03 AM
Instg8er
Dec 21, 2001 06:19 AM
FAST4DR
Sep 23, 2001 05:58 AM
