code 45
Old Jul 13, 2002 | 10:16 AM
10seconds's Avatar
Honda-Tech User
Default code 45
Im getting code 45 which is "system running to lean or to rich". i have a 98 cx and after I put the EX intake manifold and AEM cold air intake I got the code. I tried to bolt on a 96 prelude si fuel regulator but it doesnt fit. Some people keep telling me to just get a FPR like B&M or AEM or something like that. So my question is will this clear my code?
Steve
Old Jul 14, 2002 | 11:11 PM
10seconds's Avatar
Honda-Tech User
Default Re: code 45 (jdmimports79)
i have reset the ECU a couple of times
steve
Old Jul 15, 2002 | 01:53 AM
Unjockable's Avatar
New User
my car is throwing the code also. I really don't know what the problem is. People are saying get the VAFC.
Old Jul 15, 2002 | 11:51 AM
10seconds's Avatar
Honda-Tech User
Default Re: code 45 (Unjockable)
anybody know if i get the B&M regulator will that take my code away, im probably going to end up doing that, unless someone tells me otherwise by the time i get one.
steve
Old Jul 24, 2002 | 08:45 AM
LTB420's Avatar
dose any one have any new info on this freeken code 45?
Old Jul 29, 2002 | 12:44 PM
10seconds's Avatar
Honda-Tech User
Default Re: code 45 (LTB420)
what kind of info are you looking for, from what i know code 45 means your car is running lean or to rich. when did you start to throw the code
Old Jul 29, 2002 | 01:39 PM
LTB420's Avatar
I started geting it once i put in my venom injectors and aem cai. is there a set fuel preshure that i can set my fpr to so as to eliminate the code? i've tried playing around with fuel preshure with no luck.
Old Jul 29, 2002 | 02:00 PM
10seconds's Avatar
Honda-Tech User
what size injectors are they? so your car is runnign to rich. hmm..... i might be wrong but you might have to get a SAFC or a VAFC whichever one you want. the FPR can only do a little but both a AFC and a FPR can work really well together, atleast that is what im told. also what kind of motor do you have and what kind of mods do you have, for all i know you could be running lean. let me know asap, i will do my best to help you out.
steve
Old Jul 29, 2002 | 03:17 PM
wetwillly2's Avatar
could have a bad 02 sensor
Old Jul 30, 2002 | 05:45 AM
LTB420's Avatar
i have an ls motor with 280cc injectors, ihe and some crower 402 cams. i have also been thinking about getting the SAFC. do you know about how much do they run?
Old Jul 30, 2002 | 06:03 AM
LTB420's Avatar
Default Re: code 45 (wetwillly2)
i was thinking that could have been the problem so i picked up a new set of O2 sensors and installed them. i had no luck the wierd thing is that the CEL just go's on and off intermittently.
Old Jul 30, 2002 | 10:08 AM
10seconds's Avatar
Honda-Tech User
the safc is about 300 and the vafc is about 325, just get a VAFC that way if you ever go VTEC you already have it, that way you save 325 in the long run. does your car put out black smoke alot? i think your going to have to get some type of AFC and lean your car out a little, im guessing your car is OBD2 also. i hate OBD2 after owning a OBD1 car and a OBD2 car i will never again go with OBD2.
steve
Old Jul 30, 2002 | 01:51 PM
Unjockable's Avatar
New User
so the VAFC will make the check engine light go away? How does that thing work? Where do you hook it up to?
Old Jul 30, 2002 | 02:25 PM
EE_Chris's Avatar
This code is set when the Long Term Fuel Trim is at its max or min, which is +/- 20%. This LTFT value is changed from feedback from your O2. If the O2 constantly shows a rich condition, the ECU begins to trim back fuel, allowing the LTFT to start heading negative. If the ECU still sees that the O2 is rich...it keeps on repeating this cycle.
Now, that does not mean your O2 is bad....like I said, its what your O2 is reporting to the ECU.
Will the VAFC cure your problem...I'm not gonna say it will, cuz I don't know. However, I do know that until you bring your fuel mixture into a range that the ECU can work with...you will get this code.
Old Jul 30, 2002 | 07:19 PM
BreakStuff's Avatar
New User
Default Re: code 45 (EE_Chris)
Well said Chris
https://honda-tech.com/zerothread?id=232985
Old Jul 31, 2002 | 05:54 AM
LTB420's Avatar
Thanx for all the info from everyone.
i think i am going to try the VAFC and see what it can do.
tdbaas
Apr 21, 2017 09:11 AM
stocker2shocker91
Dec 13, 2006 04:17 PM
