Running insanely rich. JDM D15B
Old May 1, 2008 | 05:11 PM
leoaa777's Avatar
Default Running insanely rich. JDM D15B
So I have a 1994 CX Hatch with a OBDI D15B. I did search but when I tried to bump old topics no-one answered my questions.
The problem is as it follows. I start the car and I can distinctly smell gasoline from the tailpipe. Raw unburned gas. There are no codes and I jump the connectors just in case, nothing. Also, when on high rpms, there is a black smoke out the tailpipe.
Question. I did my own timing belt and all my work. I burnt a valve a while back on nitrous and rebuilt the head as well so I did all of it.
Q? Could my timing being off cause this gas smell and the high rpm problem?
Q2? When I connected the nitrous I had the fuel line split. Would the high pressure from the nitrous cause a faulty FPR and this way causing the shitty mileage and extra gas thrown in the engine.
The plugs seem fine, I had a turbo GSR so I can read them just fine.
I got 30 mpg on a recent trip, maybe 4 days ago. However I get maybe high teens in city driving and both are way below the gas mileage it should be getting.
Old May 1, 2008 | 05:22 PM
Jimmy's Avatar
Global Moderator
What ECU are you running?
Old May 1, 2008 | 05:33 PM
JohnnyWash1's Avatar
Default Re: (Jimmy)
Are you running the stock D15B8?
Old May 2, 2008 | 07:59 AM
leoaa777's Avatar
Default Re: (Jimmy)
Im running P08 ecu. JDM D15B.
Old May 2, 2008 | 08:06 AM
Ice78transam's Avatar
Default Re: (leoaa777)
Really sounds like a valve is blown. However seeing as no one is perfect and you did your own timing adjustment, i would look into that, too much overlap can cause injected fuel to escape out the exhaust valve. Any backfiring?
Old May 2, 2008 | 08:49 AM
wonder squirrel's Avatar
Default Re: Running insanely rich. JDM D15B (leoaa777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leoaa777 &raquo;</TD></TR><TR><TD CLASS="quote">So I have a 1994 CX Hatch with a OBDI D15B. I did search but when I tried to bump old topics no-one answered my questions.
I got 30 mpg on a recent trip, maybe 4 days ago. However I get maybe high teens in city driving and both are way below the gas mileage it should be getting. </TD></TR></TABLE>
Have you checked the fuel pressure?
Old May 2, 2008 | 03:13 PM
leoaa777's Avatar
Default Re: Running insanely rich. JDM D15B (wonder squirrel)
About 40 psi of FP.
Old May 4, 2008 | 10:22 AM
leoaa777's Avatar
b umps
Old May 4, 2008 | 12:39 PM
MonkeyMagic's Avatar
guarantee it backfired into the intake manifold and cooked your intake air temp sensor. as this is the only sensor that has the power to make your car run unreason ably out of tune. and i've seen it happen so many times before.
replace that lil white sensor on the manifold and it should fix it. i bet it looks nasty when you take it out.
Old May 4, 2008 | 12:49 PM
Default Re: Running insanely rich. JDM D15B (MonkeyMagic)
Grab a multimeter and test the sensor. No sense in throwing money at it blindly.
Old May 4, 2008 | 12:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wonder squirrel &raquo;</TD></TR><TR><TD CLASS="quote">Grab a multimeter and test the sensor. No sense in throwing money at it blindly.</TD></TR></TABLE>
true
but if it looks like over-cooked hot dog, its usually a good indicator
Old May 4, 2008 | 03:34 PM
leoaa777's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic &raquo;</TD></TR><TR><TD CLASS="quote">
true
Ill check that as soon as possible. I just got to find my multimeter.
Old May 4, 2008 | 03:35 PM
leoaa777's Avatar
But wouldnt a sensor like that throw a code? I am not getting any CEL
venomzz
28
Dec 14, 2007 05:44 AM
XxJDMugenCivicxX
29
Feb 14, 2007 06:25 PM
Mark80
Oct 30, 2006 10:59 AM
lsteggy
Dec 17, 2002 04:01 AM
