Installing factory CD/ radio
Old Jul 13, 2002 | 09:11 AM
Esteban29304's Avatar
Default Installing factory CD/ radio
Have 97 Accord with Standard AM/FM cassette. Will factory CD for same year fit without any problems.[ wiring, etc?]
Old Jul 13, 2002 | 09:53 AM
-RedneckDave-'s Avatar
Working
Default Re: Installing factory CD/ radio (Esteban29304)
it should there would be no reason why it should not work in my mind. By the way why don't you just get an aftermarket deck
Old Jul 13, 2002 | 10:39 AM
YeuEmMaiMai's Avatar
as long as it is the radio with the "CD" option you can tell becaus your am button will also have CD on it and you will have a repeat button as well
edit added the following link
http://www.hondaautomotiveparts.com/.../16643_01.html
[Modified by YeuEmMaiMai, 7:41 PM 7/13/2002]
Old Jul 13, 2002 | 10:57 AM
carolinaACCORD's Avatar
are you talking about putting a whole new deck in radio/cd/everything,
or just the cd player?
Old Jul 13, 2002 | 01:34 PM
Default Re: Installing factory CD/ radio (carolinaACCLUDE)
I am talking about removing the current radio, with cassette, & getting radio with Cd from junkyard. Present radio does not have CD on button.I want to keep it looking original. Thanks
Old Jul 13, 2002 | 10:18 PM
CmptchAV6's Avatar
Yes as long as you get it from around the same year everything will work perfectly. I think honda changed the wireing connections for the audio system in 1998 so you should be fine as long as you get one from the same generation as yours.
Old Jul 14, 2002 | 03:27 AM
Default Re: Installing factory CD/ radio (CmptchAV6)
Thanks to all for the help.
Old Jul 14, 2002 | 03:34 AM
Chiovnidca's Avatar
I think all the stock radios with c/d were antitheft, so you will also need the five digit radio code.
Old Jul 14, 2002 | 04:08 AM
Default Re: Installing factory CD/ radio (Chiovnidca)
take the receipt and the S/N from the radio to your honda dealer, they will take care of getting you the code
ajl
Audio / Security / Video
Nov 4, 2007 10:10 AM
freezerman
Aug 25, 2007 05:56 AM
Sarge! Carry On!
Oct 28, 2006 10:41 AM
civic-cpe
Aug 11, 2002 12:21 AM
civic-cpe
Jul 29, 2002 11:21 AM
