pinholes...can i get rid of em??
is it thru the clear coat only? if its thru the paint too then you will have to wet sand it out. how much thinner did you mix in with the paint? if the climate is hot and you put to much thinner in it will evaporate too fast and cause pinholes. also think about lengthening your setting time. what was you viscosity of the paint? use a Zahn #1 or #2 cup. should be about 18-35 seconds for the paint to drain. hopefully that helped.
phoenix_iii
Paint and Body
10
Oct 10, 2023 11:58 PM
