cam shaft problem?
Old May 1, 2008 | 11:44 AM
Xuelor5's Avatar
Default cam shaft problem?
i have a question on cam shaft, i have a 94 d16z6, and a d16y8. i'm trying to switch over the cam shafts, i have a problem. i tooken out both cam shafts and try to put it back together, but i don't really know how to put it back together. i'm wondering if anyone has a diagram on putting it back together will be much help!!!
Old May 1, 2008 | 12:42 PM
24TEN's Avatar
PHANTOM MENACE
#1 "TOOKEN" is not a real word.
#2 You took it apart but don't know how to put it back together?!
#3 If the whole thing is in the car still, rotate your crank to TDC. Then place the camshaft with the marks on the camgear properly set for TDC per it's specific motor (D16Z6 cam TDC is different from a D16Y8). Then you install the valve train/rocker arm assemblies. Pay attention to the arms and make sure they are aligned correctly. Be sure to tighten the bolts in the correct order and to the correct torque spec to avoid possibly warping the camshaft.
#4 If you have no idea what #3 is about, go buy a Chilton's or Haynes manual...or better yet, an FSM.
This is the quickest thing I can reference. Hopefully, you didn't take the rocker arms apart...
on2wheels
Jun 13, 2007 09:01 PM
crx_of_fury
May 14, 2005 10:56 AM
CivicSoul
May 25, 2003 02:09 PM
