Timing Belt Check up
Old May 1, 2008 | 08:32 AM
ajvb65's Avatar
Default Timing Belt Check up
I bougth an old honda civic 1998 EX with 250K milage and it works fine to me. I am worried about the timing belt if it is time to replace. Is there any easiest way to check if i need to replace or not without removing all these belts and pulleys?
Old May 1, 2008 | 08:44 AM
Padawan's Avatar
Darth ModerVader
Default Re: Timing Belt Check up (ajvb65)
There is no way to tell if it needs to be replaced just by looking at it, unless there are obvious cracks, deterioration, or missing teeth. With that sort of mileage, you should replace the belt either way. It's a whole lot easier and cheaper than replacing a blown engine.
Old May 1, 2008 | 09:41 AM
ballinboosi's Avatar
Default Re: Timing Belt Check up (Padawan)
X2
Old May 1, 2008 | 05:17 PM
nmhuntr's Avatar
Change belt and water pump at the same time. most of the labor cost is done by the time you get to the belt anyway.
chahsiubow
Dec 14, 2007 10:01 PM
honda94accord
Apr 10, 2007 05:39 AM
JDMtype Eg6
Feb 18, 2007 05:45 AM
xstalkrx
Jun 29, 2004 08:03 PM
