[HELP]Water entering sunroof JDM EG6 stock sunroof
Old May 1, 2008 | 12:23 AM
Lim Ling Yang's Avatar
Default [HELP]Water entering sunroof JDM EG6 stock sunroof
Currently my ride is JDM EG6 with stock sunroof.
This sunroof does not need rubbers to block/stop water from entering it.
It however allows the water to flow down to the front and back of the car.
But now the right side of the sunroof is collecting water. The left side is still doing fine. I just pour water and it flows right down.
So what can I do?
PS:I just replaced the rubbers around my front windshield.Could this be the cause of the problem?
Old May 1, 2008 | 12:45 AM
NOFX's Avatar
H-T White Ops
Have you checked that the drains are clear? There is usually one in the front and one in the rear.
Old May 1, 2008 | 12:48 AM
Default Re: (NOFX)
How to check?
And where are the drains?
Old May 1, 2008 | 01:10 AM
NOFX's Avatar
H-T White Ops
Old May 1, 2008 | 01:49 AM
Default Re: (NOFX)
How to fix it?
And jdm eg6 got how many drain pipes?
4 right?
2 front 2 back?
Where to locate them?
Modified by Lim Ling Yang at 4:01 AM 5/1/2008
Old May 1, 2008 | 02:08 AM
NOFX's Avatar
H-T White Ops
The EG6 has nothing special about the moonroof. It's the same as all other '92-'95 Civic moonroofs. It's just like shown above.
TWO moonroof drains.
LOOK in the picture I posted to see where they are.
I've heard of using compressed air to clean them out. You're going to have to force it out somehow.
Old May 1, 2008 | 03:03 AM
Default Re: (NOFX)
But if I am not mistaken I have two drain pipes at the front.
Hmmmm.
Compressed air?
Is there any way I could find the pipes?
And if I were to remove the windshield could I see those pipes?
Old May 1, 2008 | 09:30 AM
NOFX's Avatar
H-T White Ops
Default Re: (Lim Ling Yang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lim Ling Yang &raquo;</TD></TR><TR><TD CLASS="quote">But if I am not mistaken I have two drain pipes at the front.
Hmmmm.
Compressed air?
And if I were to remove the windshield could I see those pipes?</TD></TR></TABLE>
According to Honda, you only have one drain in the front and one in the back.
Removing the windshield will not help you find the drain.
Compressed air is supposed to force anything that's stuck in the tube out.
Old May 2, 2008 | 03:45 AM
Default Re: (NOFX)
Hmmmm.
Compressed air?
Old May 2, 2008 | 04:14 AM
instructor74's Avatar
yeah try 4 drain pipes for the 92-95 sunroof I am looking at them right now 2 for the front 2 for the rear.
Old May 2, 2008 | 12:07 PM
NOFX's Avatar
H-T White Ops
Default Re: (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">yeah try 4 drain pipes for the 92-95 sunroof I am looking at them right now 2 for the front 2 for the rear. </TD></TR></TABLE>
That's strange since Honda only shows one for the front and one for the rear.
The image above is for a 1995 Si hatch.
Old May 4, 2008 | 03:40 PM
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
The image above is for a 1995 Si hatch.</TD></TR></TABLE>
Yes but look at the qty for both the front and rear drain tubes it list 2 of each
Old May 9, 2008 | 11:09 AM
Speed94's Avatar
Theres def. 4....I just replaced mine. Put everything back together only to realize that the passenger front drain is clogged lol
Old May 9, 2008 | 02:55 PM
NOFX's Avatar
H-T White Ops
It's just weird that the EPC would only show some of the parts.
bad 91 teg
33
Oct 1, 2011 02:34 PM
dlenoxx
Dec 2, 2010 12:05 PM
idriveadelsol7
Audio / Security / Video
Apr 10, 2006 12:30 AM
effinnwackk
10
Jul 15, 2005 05:31 AM
vtec69
Dec 8, 2004 05:19 PM
