lowering springs
Old Jul 13, 2002 | 06:54 AM
HatchBox's Avatar
Skoobie no more...
Default lowering springs
Ok i just ordered lowering spring for my 90civ hatch...2 inch drop...do i need to replace anything with them....like shocks? or anything
Old Jul 13, 2002 | 06:56 AM
EP3_05's Avatar
Default Re: lowering springs (xxkenyon419xx)
I would replace the shocks while you are changing the springs since you will eventually have to replace the stock ones. The stock shocks will blow out when you are lowered. They are not designed for lowering.
Old Jul 13, 2002 | 07:02 AM
HatchBox's Avatar
Skoobie no more...
Default Re: lowering springs (91civic)
i dont got the money for good ones (the ones that are like 1thousand for a set)...so is there some kind of shock i could get that are cheap like from monroe or something....
Old Jul 13, 2002 | 12:33 PM
rice_classic's Avatar
Default Re: lowering springs (JDMhondaslut)
tokico hp's? the blues ones! great with 2" lowering springs..
Old Jul 13, 2002 | 12:40 PM
HatchBox's Avatar
Skoobie no more...
Default Re: lowering springs (rice_classic)
how much?
Old Jul 13, 2002 | 02:53 PM
90civichbsi's Avatar
i think they have agx adjustables 360 for a set on groupbuycenter.com thats what im proolly gonna get
Old Jul 13, 2002 | 05:02 PM
REDBARON's Avatar
Default Re: lowering springs (90civichbsi)
The Tokico blue's work good with simple lowerings springs. I had them on my Si, and they were great, but now I have GC coilovers and they don't like the higher springs rates. I'm going with Koni yellow's to lower it back to 2" with the GC.
Old Jul 13, 2002 | 09:36 PM
.Ryan's Avatar
Don't Trust Anyone
If you dont know anything about shocks, then you dont need the "1thousand for a set" shocks anyways.
Old Jul 14, 2002 | 12:17 PM
HatchBox's Avatar
Skoobie no more...
Default Re: lowering springs (SpoonSportsEF7)
first off shut up I do know about shocks. but i dont want to spend a grand on ajustables when i can buy a decent no ajustable set that will work just fine. then i can spend the money i saved a accually get my DX a new motor so it will accually move...ight peace
Old Jul 14, 2002 | 01:40 PM
.Ryan's Avatar
Don't Trust Anyone
Well I dont think you do, since there are a lot of shocks that are adjustable and dont cost a grand.
Old Jul 14, 2002 | 02:10 PM
EG8R's Avatar
I think he used "a grand" as an example.... Bleh....
Old Jul 16, 2002 | 09:52 AM
V3locity's Avatar
go ahead and get a camber kit for the front unless you like buying tires....My H&R's are eating tires....
Old Jul 16, 2002 | 09:59 AM
HatchBox's Avatar
Skoobie no more...
Default Re: lowering springs (illdezignzminime)
how much is that gonna be?
Old Jul 16, 2002 | 11:31 AM
V3locity's Avatar
about $120 for both sides (front only) the rear isn't that bad and can be fixed with a few washers...
Old Jul 16, 2002 | 11:59 AM
my setup barely changed my camber.. 2" drop and my camber is basically factory.. I'll give the specs from my last alignment as soon as I can find them.
Cali_Realist
Oct 26, 2013 08:08 PM
MYSI
24
Apr 5, 2006 08:31 PM
v-tec maz
Mar 2, 2005 10:24 AM
Chubakon
Sep 7, 2004 08:18 PM
