B18C1 Axel Question
Old Apr 30, 2008 | 06:32 PM
infinitypro12's Avatar
Default B18C1 Axel Question
Noob question, I know, but I was wondering how to tell if my axles are with ABS or not because I am ordering one, that the CV ripped on. I bought an 96 Civic EX with a B18C1 in it and rear disc conversion. Where should I look to tell if I need an axle with ABS or should just order without. thanks.
Old Apr 30, 2008 | 08:10 PM
v8 integra's Avatar
Default Re: B18C1 Axel Question (infinitypro12)
does the car have abs?
Old Apr 30, 2008 | 08:14 PM
geebs's Avatar
Default Re: B18C1 Axel Question (v8 integra)
its most likely non abs
Old Apr 30, 2008 | 09:12 PM
instrument's Avatar
you can use abs axles in a non abs car, they tend to be more expensive but they also seem to always have the abs in stock...
the difference is the metal ring around the cv side
Old Apr 30, 2008 | 09:15 PM
The problem is I am not sure and the rears have been switch from drums to discs. Ha ha, it's these little things that come up, I'm kind of wishing I had done the swap myself. But thanks for the input.
Default Re: (instrument)
instrument, so it would almost be safer to buy the ABS, the price difference is like $10 I think and it will still work?
Old Apr 30, 2008 | 10:32 PM
ejprimo's Avatar
Default Re: (infinitypro12)
i use gsr integra axles in my 94 b16a civic w/o abs.
Old May 1, 2008 | 09:10 PM
Default Re: (ejprimo)
I have also conferred at work and it was as Instrument said, and I might as well go ABS since it was an option on the 96 Civic EX, and I have money so it isn't an issue. Honda-tech helps me again, thanks all!!!
j0keefe21
Feb 14, 2009 08:13 PM
realis9
May 30, 2008 12:55 AM
b16bri
Jan 22, 2008 04:56 AM
johnny_tdi
May 2, 2006 08:55 PM
philosofy1
Oct 26, 2005 02:08 PM
