Just sprayed my 2nd layer clearcoat, need help (it's dull)
Old Apr 30, 2008 | 05:34 PM
Rikaro's Avatar
Default Just sprayed my 2nd layer clearcoat, need help (it's dull)
I just did my second layer of clearcoat after my first one 20 mintues ago. The first layer was very shiny but the second layer is very dull. Is it possible to fix this on my next layer? Also i'm doing this on carbon fiber.
Old Apr 30, 2008 | 06:09 PM
slacks's Avatar
Default Re: Just sprayed my 2nd layer clearcoat, need help (Rikaro)
try here
https://honda-tech.com/zeroforum/84
Old Apr 30, 2008 | 06:19 PM
Rikaro's Avatar
Default Re: Just sprayed my 2nd layer clearcoat, need help (slacks)
thanks!
Old Apr 30, 2008 | 06:28 PM
z6hatchboy's Avatar
I dont know the products your using, but when i use dupont and u-tec i usually let about 5-10min for flashing between coats. Did you spray it the same? To make it shine you need to go slower, but not slow where you'll run it. If its not too bad you can wet sand with 1500-2000 and buff it.
ek-g6
Paint and Body
Oct 15, 2007 08:32 PM
ej1 rep
Sep 24, 2007 08:14 PM
S repcivicsir
18
May 4, 2005 07:27 PM
japmarket1
Apr 7, 2005 05:38 PM
SPOOLINmatt
Feb 15, 2005 09:02 PM
