PLX M300 wiring question
Old Apr 30, 2008 | 03:49 PM
blkb18's Avatar
Default PLX M300 wiring question
I am running a JRSC 96 GSR with a Hondata obd2 socketed p28. I only intend to use the wideband sensor. What is the best pinfit to tap into for the white wire? I have been told to use the ELD input. Will disableing the real ELD input cause any problems with idle or voltage regulation? Could I keep the ELD and wire the white wire to the primary o2 input? I understand there is a pull down menu in the s300 where you can choose the ELD as an input. Is the primary o2 input in that menu too? Thanks
Old May 1, 2008 | 03:27 AM
blkb18's Avatar
Default Re: PLX M300 wiring question (blkb18)
bump
RoB316
Jul 24, 2007 10:10 AM
5thGenFanatic
16
Aug 28, 2005 05:38 PM
turboH22Aakkord
Aug 22, 2005 10:48 AM
redrum eg6
Jun 21, 2004 07:42 AM
boostedcvc
Oct 13, 2003 11:46 AM
