why would a 5 speed civic start with out pushing in the clutch?!
Old Apr 30, 2008 | 03:30 PM
grams94eg6's Avatar
Default why would a 5 speed civic start with out pushing in the clutch?!
aight i have a 97 civic coupe... and i can start the car with out even pushing in the clutch! car seems stock ... so don't think that anybody would have mess with it..
also heater does not work blows out air but nothing.... plus also the car while driving it .. it would kinda of stall or pull back.. when i press on the gas..
the motor in the car seems to be one from a junk yard or something.. it has yellow writing on it...
could it be that they have made it auto to standard ?! it has the auto cluster on it now... i don't know if they switched out the computer or not....
Old Apr 30, 2008 | 03:32 PM
cherroneballs's Avatar
look up at the clutch pedal and there will be a switch that has wires going into it it may be unplugged or shorted out.
Old Apr 30, 2008 | 05:05 PM
grams94eg6's Avatar
Default Re: (cherroneballs)
will check that out 2night thanks
Old Apr 30, 2008 | 05:07 PM
groundzerocivic's Avatar
Default Re: why would a 5 speed civic start with out pushing in the clutch?! (grams94eg6)
neutral safety switch
Old Apr 30, 2008 | 05:21 PM
z6hatchboy's Avatar
Default Re: why would a 5 speed civic start with out pushing in the clutch?! (groundzerocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by groundzerocivic &raquo;</TD></TR><TR><TD CLASS="quote">neutral safety switch </TD></TR></TABLE>
I think that with auto trans'. Check the clutch pedal switch as mentioned above. It may have been a auto at one time and has been swapped and not done properly
Old Apr 30, 2008 | 07:11 PM
ltrkstr2k's Avatar
Default Re: why would a 5 speed civic start with out pushing in the clutch?! (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">
I think that with auto trans'. Check the clutch pedal switch as mentioned above. It may have been a auto at one time and has been swapped and not done properly </TD></TR></TABLE>
+1 especially if you said it has a auto cluster in it. if you have any CEL's then you may still have the auto ecu in it. but if no Cel's then its probaly just the clutch safety switch.
hfbellosa
Nov 21, 2013 03:05 PM
JaimmyACA
May 26, 2013 06:24 PM
fryman
Oct 15, 2009 10:46 PM
zc89hatch
Feb 2, 2008 09:05 AM
p0pe
Sep 20, 2003 07:52 PM
