Anyone running the omnipower 4 bar map sensor yet ?
I am going to order a hondata s300 from phearable.net. I also was trying to decide between a 3 bar and a 4 bar map sensor.
I wanted to see if anyone has any feedback on the omnipower 4 bar map sensor ?
I like the idea of a plug and play sensor that looks stock.
For those of you that have not seen the sensor I found it here: http://www.phearable.net/shopp....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sihatch19 »</TD></TR><TR><TD CLASS="quote">I am going to order a hondata s300 from phearable.net. I also was trying to decide between a 3 bar and a 4 bar map sensor.
I have sold quite a few of the B series ones, I haven't heard anything bad back on it so.....
K series will be available hopefully next week also
We have sold tons of these things & tuned a hand full of cars on them.
We have not had one single problem with any of them
I just got my first turbo build tuned using the omnipower map sensor...no issues at all man, plug n play rock, and I made 507 whp on pump
from what I read, it is a modded motorola map sensor, so i assume the performance of the omni is identical to a properly installed moto...
Glad to hear this feedback... I have one for my setup and plan on shootin for approx. 600whp and was wondering how this map sensor would hold up... We shall see soon when I get tuned on June 27th and I will post on here how it goes...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">They work great. I've got one on my car, and haven't had any issues yet. I got it from Phearable.net as well.
Honestly, it was as simple a remove and replace. Done.</TD></TR></TABLE>
I bought mine from phearable.net
for phearable.net
Mine works like a charm
for phearable.netMine works like a charm
Will the the omni or hondata both being 4bar map sensors work with the apexi power fc ecu in an itr??
The build's nearly done and i'm not sure which map sensor will be compatible with the power fc..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akira712 »</TD></TR><TR><TD CLASS="quote">I've seen pics of one come apart and heard of a second one do the same.</TD></TR></TABLE>
We've sold and installed a lot of these and have yet to hear of any issues. Any pics of these broken ones?
there's a pic on ectune, I posted the link on here somewhere.
The 2nd one I never saw just heard someone say that it came apart (again a post on here).
you could search my post and the ectune link and the other sensor blow out are both in the same thread ("peakboost hvs equip b16 dyno") sorry can't link I'm on an iPhone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
We've sold and installed a lot of these and have yet to hear of any issues. Any pics of these broken ones?</TD></TR></TABLE>
Modified by akira712 at 3:24 AM 5/28/2008
From the pictures I've seen, it looks like they used the small freescale (aka motorola) sensor is glued in there w/o any filler. The OEM sensor is filled solid, with an o-ring keeping pressure from entering the small cavity that's left. Meaning it will be prone to failure if the sensor isn't completely sealing the inlet.
http://forum.ectune.com/viewto...rt=15
I've had mine sitting in my bedroom drawer for months, just waiting to get some dyno time before putting it on. I know it should work fine with my stock b18c but why ruin a good thing!
Tuned a few cars with them, had 2 of the them fall apart while tuning. Had to switch to a 3bar map sensor. Had one of the sensors putting out a consistent voltage on the signal wire, troubleshooted the wiring and all was stock. Put a 3bar on and it worked fine. The ones that worked were great. Good thing i didnt sell the customers the sensors, they were all really pissed...
I hope we don't have any issues with mine next month Tony... Hopefully this isn't an issue
warranty or not if you dont tune at the shop you got it from your probably gonna have to switch to something else on the dyno to get your car tuned, the downtime(for lack of a better word) for these is what will turn them into a shitty product.
just like boosted hybrid said, to get the car tuned he installed a 3bar. so now the guy who bought it will have to try and get $ back for the map sensor as hes running a different one (that he will be at the mercy of the tuner to supply him with).
null.
Dec 15, 2005 06:35 PM
