STEERING FEELS LOOSE
Old Apr 30, 2008 | 02:24 PM
Nino_eg6's Avatar
Default STEERING FEELS LOOSE
HEY I HAVE A 93 HATCHBACK DX AND MY STEERING IS SUM CRAP, EVERYTIME I HIT A BUMP OR SMALL POTHOLE MY CAR PULLS TO THE SIDE AND MY STEERING WHEEL TURNS, ALSO IT SLIPS LIKE HELL IN THE RAIN I WILL BE DRIVING AT DECENT SPEEND AND MY STEERING WHEEL WILL JUSS PULL TO ANY SIDE IT WANTS. I NEED HELP WHAT DO YOU THINK IT IS BECAUSE I HAVE NO IDEA!
Old Apr 30, 2008 | 02:48 PM
themikewoo's Avatar
Check tire pressures and check that rim is balanced. My friends wheel weight fell off and this stuff started to happen.
Old Apr 30, 2008 | 04:19 PM
stock ek's Avatar
Default Re: STEERING FEELS LOOSE (Nino_eg6)
get an alignment its your best bet especially if it is pulling
Old Apr 30, 2008 | 06:59 PM
1990_integra_DA9's Avatar
did you do any recent suspension stuff? But I would suggest an alignment but make sure everything in the steering is tight. SOunds like it could be a caster issue with the alignment.
Old Apr 30, 2008 | 08:10 PM
Midori Green's Avatar
Default Re: STEERING FEELS LOOSE (1990_integra_DA9)
check your tire pressure and also check your tie rods im pretty sure your tie rods are bad so after you get new ones i would also get an alignment
Old Apr 30, 2008 | 08:22 PM
95delsolz6's Avatar
Don't use the CAPS LOCK, it's hard to read.
Old May 2, 2008 | 02:29 AM
Nino_eg6's Avatar
Default Re: STEERING FEELS LOOSE (Midori Green)
aite thanks alot guyz....yea thats wat i thinkin also the tie rods because after i bout the car and took of the front bumper i realized it had been in an accident the radiator support looks like its been banged into place and the reinforcement bar is dented!.....
Old May 15, 2008 | 12:44 AM
Nino_eg6's Avatar
i am takin it tomorow morning to mechanic to get the right lower control arm replaced bushings were gone and goin to get an alignment nd see if it helps
bigtimegambler
17
Dec 12, 2015 04:16 PM
cgap
Mar 22, 2008 01:30 PM
Charri
Oct 17, 2007 11:26 AM
BrokenRex
12
Nov 16, 2005 07:39 PM
93civicsedan
13
Mar 6, 2005 06:52 PM
