b16a3 to a 99 si
Old Apr 30, 2008 | 02:24 PM
h22_em1's Avatar
Default b16a3 to a 99 si
hey there guys im new to the place and i really need a little help im swaping an engine that i got from a 95 del so lb16a3(obd1) in to my 99 SI(obd2), i [freak]ed my oringinal engine and i know have this one to swap, the only problem im having is rewiring the distributor and the alternator, i have everything else ok but i just dont know what color wire connects to what other wire, i would apreciate any help you guys can give me
Old Apr 30, 2008 | 03:27 PM
GSRcivicDX's Avatar
Default Re: b16a3 to a 99 si (h22_em1)
Not sure if your old motor was a B16A2 or an H22 due to your screen name but if you had the A2 just use your stock harness and ECU then all you have to do is swap over the altenator, dizzy and injectors from the A2 and everything will plug right in. You will also have to do the CKF bypass trick.
99em1b18c1
Feb 25, 2013 12:26 AM
tysonboy
13
Oct 15, 2009 03:19 PM
sohclude
Feb 23, 2009 03:12 PM
kyden
Oct 29, 2004 07:32 AM
