Hows My Timing Look? i need some criticism about this
Old Apr 30, 2008 | 12:53 PM
celltoolz's Avatar
Default Hows My Timing Look? i need some criticism about this
Just wondering if this is off a tooth or how it looks to you guys. This is my first build/swap so any input or criticism is welcomed. Thanks again HondaTech's.
Old Apr 30, 2008 | 01:49 PM
R you serious's Avatar
Default Re: Hows My Timing Look? i need some criticism about this (celltoolz)
are the cams locked?
Old Apr 30, 2008 | 01:54 PM
celltoolz's Avatar
no, but the timing belt is on you just cant see it in the picture.
Old Apr 30, 2008 | 02:56 PM
Tiger_Si's Avatar
ummm i am having the same problem, but my ITR is bone stock.
Old Apr 30, 2008 | 03:23 PM
celltoolz's Avatar
Hows your R running with that timing. Pretty good or bad. I adjusted my Fuel Pressure Regulator to about 30psi and it started idling a little better but as soon as it warmed up the idle dropped. I just need to tune my car thats the major problem right now. Im running 370cc Injectors and the ECU still thinks that there stock 240cc. This weekend i'm going to go get it tuned and hopefully everything works out well.
Old Apr 30, 2008 | 06:11 PM
Tiger_Si's Avatar
Default Re: (celltoolz)
running...
pretty shitty, i am bouncing all over when idling and not running well at all.
hope the tuning will help you.
91 EF DX
17
Jul 15, 2013 05:40 AM
jpnolan
Jun 10, 2013 04:29 PM
ToTriggerHappy
12
Jun 9, 2010 06:49 AM
DraginTeg93
Jan 29, 2010 12:02 AM
dreweg
Jul 14, 2003 10:33 AM
