question about changing wheel studs?
ok so i am in the proces of swapping in my coilovers., and i need some new wheel studs. there is no way to get the studs out.....am i going to have to pull my axle out just to change my wheel studs or is there a easier way? thanks
you gotta do alot....kinda...have to push the axle in and pull the hub out. there is a tool that is used to do it, i had a bad run in recently with trying to do this...ended up taking it to the dealership, good luck
HCivExoo
Mar 19, 2005 09:05 PM
