Fog Light Wiring Question
Old Apr 30, 2008 | 09:51 AM
civicSIfnatic's Avatar
Default Fog Light Wiring Question
Hey guys,
I need a little electrical help. I have a 2000 Si with JDM fog lights installed. Problem is that I need to get my car inspected in the state of Virginia, and by law the fog lights are required to turn off when the high beams are turned on; mine do not.
Anyone know how to wire them up so it will happen?
Thanks in advance.
Old Apr 30, 2008 | 10:09 AM
justlook's Avatar
usually the correct way to wire foglights would be via switch...press on and off. i guess yours is not wired that way?
Old Apr 30, 2008 | 10:10 AM
TeamRPM_ZC's Avatar
Default Re: Fog Light Wiring Question (civicSIfnatic)
get your red wire (power) from the fog switch and run it to your light fuse, then when you turn your lights on your fogs can be turned on that way
Old Apr 30, 2008 | 10:15 AM
Default Re: (justlook)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justlook &raquo;</TD></TR><TR><TD CLASS="quote">usually the correct way to wire foglights would be via switch...press on and off. i guess yours is not wired that way?</TD></TR></TABLE>
The lights are operated by a switch and are wired that way. It's just the law here in Virginia states that they HAVE to go off when you turn the high beams on. They don't care if you have a switch or not.
Old Apr 30, 2008 | 10:27 AM
iOn's Avatar
iOn
My OEM fogs turn off with the high beams on :x
Old Apr 30, 2008 | 10:31 AM
Default Re: (iOn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iOn &raquo;</TD></TR><TR><TD CLASS="quote">My OEM fogs turn off with the high beams on :x</TD></TR></TABLE>
Are yours USDM? Mine are the JDM OEM fogs and I have reason to suspect that the switch harness for the JDM lights is different from the USDM. Can anyone confirm?
Old Apr 30, 2008 | 10:33 AM
TeamRPM_ZC's Avatar
Default Re: (civicSIfnatic)
i bought the JDMCARBOY ones and they didnt work so i made my own switch, and it had the oem look, but didnt work
Old Apr 30, 2008 | 07:45 PM
Haz31203's Avatar
Simple way just to pass is connect a switch
Old Apr 30, 2008 | 07:58 PM
z6hatchboy's Avatar
Default Re: Fog Light Wiring Question (TeamRPM_ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamRPM_ZC &raquo;</TD></TR><TR><TD CLASS="quote">get your red wire (power) from the fog switch and run it to your light fuse, then when you turn your lights on your fogs can be turned on that way</TD></TR></TABLE>
Do this or splice your power wire to the low beam wire at the headlights. I say try a diff. garage also maybe.
Old Apr 30, 2008 | 08:12 PM
v8 integra's Avatar
can u disconnect ur fogs for inspection???? im sure u dont need fog lights for inspection...
Old Apr 30, 2008 | 08:17 PM
Blzdeep's Avatar
Default Re: (v8 integra)
I believe if you use a relay and connect your fog lights to you regular headlights, then when you turn on your brights the fogs will go off with the lows. Just make sure its relayed so you dont blow fuses.
Old May 8, 2008 | 07:44 PM
*UPDATE BUMP*
I got a US switch harness and modified it so I could run my fog lights without having my headlights on.
I have a new problem though. The JDM switch does not operate like the US switch. I have to hold it down to keep the fog lights on.
Can anyone with wiring experience jump in on this? I would really like to get this switch to work.
(Honda has discontinued the US switch, so getting one it a no go.)
Old Aug 21, 2008 | 09:42 PM
biggjerryc's Avatar
just unhook them. the foglights must operate correctly if they are going to operate at all but there is no law saying they have to work. just unhook them for inspection and say they dont work.
Old Aug 21, 2008 | 09:48 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicSIfnatic &raquo;</TD></TR><TR><TD CLASS="quote">*UPDATE BUMP*
(Honda has discontinued the US switch, so getting one it a no go.) </TD></TR></TABLE>
Sounds like a broken switch. Happened to a DEPO switch I used to have.
USDM foglights are supposed to (by law) turn off when the high beams come on.
dvsteg
Jun 18, 2009 10:13 AM
Azxster
Audio / Security / Video
Apr 20, 2007 06:38 PM
NTCustoms
Oct 3, 2006 06:08 PM
4DRmafia
Jul 12, 2004 10:51 PM
acuraLSSE95
Feb 28, 2002 06:39 PM
