H22a swap into EG sedan whislt retaing P/S & A/C.
Old Apr 30, 2008 | 08:26 AM
II 1ND3X II's Avatar
Default H22a swap into EG sedan whislt retaing P/S & A/C.
Hi guys im from Australia... and there's very little knowledge on this topic.
I've looked at the usual (who I know of) mount kits so suit an H22a conversion
into a EG sedan which I believe you guys call Ferio's.
Anyway... Hasport claims there EGH2 kit can retain P/S, but not A/C.
Innovative's H series EG/DC mounts claim they can retain both P/S & A/C.
But when I emailed Innovative in regards to what A/C parts & installation procedure
they gave me nothing... great customer support... not.
I want both luxuries
Is the A/C side of things a custom job, or just some mix & matching of either Prelude
or Accord A/C bits.
Are there any other mount company's that make P/S & A/C basically a simple swap?
I'm a noob in this area so any help will be much appreciated
Thanks.
Old Apr 30, 2008 | 09:17 PM
Bump... Come on guys, I here of EG's with P/S & A/C in the states... what mounts or A/C bits are need to make the conversion work with the luxuries ?
I don't care what mount manufacture I use, as long as they have provision of both P/S & A/C.
Come on someone help an Ozzie out!
Pic's , Links or Info whatever...
Modified by II 1ND3X II at 10:23 PM 4/30/2008
Old Apr 30, 2008 | 09:36 PM
Plz move to technical - Hybrid section....
May have more luck with answers there???
Old May 1, 2008 | 12:12 AM
ALLMOTORH22A's Avatar
Default Re: (II 1ND3X II)
would also like to know
Old May 1, 2008 | 05:25 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (ALLMOTORH22A)
just any mounts that will allow you to keep your AC, and swap out your Power steering rack for a manual one, TRUST me you will not miss PS especially with the manual rack. It is possible to keep both, but not cost effective or a good allocation of the tiny bit of space that you will have under your hood with the h swap, not to mention if the car is powerful enough the ps is going to be counterproductive to your launches and acceleration.
Old May 1, 2008 | 05:32 AM
Default Re: (oneludesol)
i just wanted a/c
bonsnick
K Series
Mar 4, 2015 05:41 AM
Japankid
Jul 28, 2009 12:52 PM
92milanoredhatch
Apr 12, 2009 09:09 PM
ESP.net
Oct 8, 2007 12:18 AM
