Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Plugs for engine when removing heater system on B18C5
Old Apr 30, 2008 | 08:23 AM
MightyMouseTech's Avatar
Default Plugs for engine when removing heater system on B18C5
For future reference...
I am removing the heater system from my RR EG Civic with a B18C5. I am also removing the factory oil cooler. So I was trying to find a way to properly eliminate the cooler lines and heater lines. I finally found factory plugs to block off two of the spots. The hard one to find was for the heater outlet from the head, underneath the distributor, as it is 20mmx1.0 thread. But I managed to finally find one.
<U>To plug water outlet on side of head</U>.
Honda part#: 11106-PNA-300 plug, sealing
Some other handy part#'s when doing this.
<U>To plug oil cooler return line in block.</U>
Honda part#: 90083-PG1-000 plug, sealing.
I am still trying to find a water crossover tube (water pump to thermostat housing) that does not have any additional outlets on it. I will probably have to just weld up the one that I have.
Additionally, to seal up the one unused water outlet in the thermostat housing, I heated and pulled out the hose nipple, and then threaded hole with an 18mm tap and used the sealing plug from a K-series motor that is removed when installing a block heater. (directly above the oil filter housing)
sgull
Nov 27, 2012 07:01 AM
atikovi
Oct 7, 2010 05:49 PM
DELshow
Jul 26, 2006 05:23 PM
nelsond
Oct 8, 2005 12:59 PM
speedymon
Nov 14, 2002 10:44 AM
