help here
Old Apr 30, 2008 | 07:17 AM
dorkjoey's Avatar
Default help here
I was wondering on the 02 sensor end of it there is plug am I suppose take that out? also how would take out that plug from o2 sensor?
Old Apr 30, 2008 | 07:49 AM
dorkjoey's Avatar
Default Re: help here (dorkjoey)
Old Apr 30, 2008 | 08:02 AM
biggdogg's Avatar
uh......... WHAT?
Old Apr 30, 2008 | 08:05 AM
dorkjoey's Avatar
Default Re: help here (biggdogg)
This D16z6 motor. Um..my question is how do I take out plug it's from the 02 sensor from the long string plug?
[ ] ----------*02 sensor*
something like this ^
Old Apr 30, 2008 | 08:10 AM
Ice78transam's Avatar
<U>I BELIEVE</U> what you want is to unplug the entire O2 sensor unit so you can remove it from the car. You follow the cord from the top of the O2 sensor itsself and it should lead into the floor board at some point. there is a *bung* there that just pops out that allows you to access the plastic connector. then just pinch and pull apart.
Old Apr 30, 2008 | 08:21 AM
dorkjoey's Avatar
Default Re: help here (Ice78transam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ice78transam &raquo;</TD></TR><TR><TD CLASS="quote"><U>I BELIEVE</U> what you want is to unplug the entire O2 sensor unit so you can remove it from the car. You follow the cord from the top of the O2 sensor itsself and it should lead into the floor board at some point. there is a *bung* there that just pops out that allows you to access the plastic connector. then just pinch and pull apart. </TD></TR></TABLE>
how do I remove plastic connector freak won't come out.
Old Apr 30, 2008 | 08:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ice78transam &raquo;</TD></TR><TR><TD CLASS="quote">...then just pinch and pull apart. </TD></TR></TABLE> harder. break it if you must then tape it back together.
Old Apr 30, 2008 | 08:32 AM
blk92_d16's Avatar
Flat head screwdriver. Put it inbetween the plastic ridges in the moldings and turn the handle. GL!
Old Apr 30, 2008 | 09:30 AM
dorkjoey's Avatar
Default Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 &raquo;</TD></TR><TR><TD CLASS="quote">Flat head screwdriver. Put it inbetween the plastic ridges in the moldings and turn the handle. GL!</TD></TR></TABLE>
thanks guys for help.
Old Apr 30, 2008 | 09:44 AM
95delsolz6's Avatar
Default Re: (dorkjoey)
On most of those plastic plugs there is a clip underneath that you have to push down on and then slide the plug off and then you can disconnect the o2.
Old Apr 30, 2008 | 09:51 AM
Davus's Avatar
Aha, I see you're going through with previous thread.
Yeah, plastic clip is sometimes a pain. Got the exhaust manifold heat shield off yet? :-)
Old Apr 30, 2008 | 10:39 AM
dorkjoey's Avatar
Default Re: (Davus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davus &raquo;</TD></TR><TR><TD CLASS="quote">Aha, I see you're going through with previous thread.
Yeah, plastic clip is sometimes a pain. Got the exhaust manifold heat shield off yet? :-)</TD></TR></TABLE>
yeah i did only problem is 02 sensor not coming out as it wants to. well...does anyone have an idea how I should take out 02 sensor? i use 7/8 tool bolt and racket won't come out.
Old Apr 30, 2008 | 12:11 PM
biggdogg's Avatar
dude hose it down with some penetrating oil of some kind and let it marinade 4 a few. go burn one or take a nap under the car. i have a o2 socket its huge u can get a deep well thats just deep enuff and take a grind wheel and slit the side of the socket so the connector and wire hang out.
Old Apr 30, 2008 | 01:09 PM
dorkjoey's Avatar
Default Re: (biggdogg)
any other ideas beside grind and socket?
Old Apr 30, 2008 | 01:35 PM
Remington's Avatar
big *** wrench?? just sack up and do it it's gonna suck but hit it with the pb blaster, let it sit and take the wrench to er, if grinding on the socket worries you, either get a cheapo one you don't care about and cut it or just get the O2 socket
Old Apr 30, 2008 | 01:40 PM
ejprimo's Avatar
Default Re: (Remington)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Remington &raquo;</TD></TR><TR><TD CLASS="quote">just sack up</TD></TR></TABLE>
Old Apr 30, 2008 | 01:42 PM
ejprimo's Avatar
Default Re: (ejprimo)
the longer the wrench the eaiser. or put two wrenches together to make one long one.
Old Apr 30, 2008 | 01:51 PM
Remington's Avatar
big *** pipe works too, but really it shouldn't be too hard if you let some penetrating oil set in first
Old Apr 30, 2008 | 02:03 PM
dorkjoey's Avatar
alrighty thanks again.
Old Apr 30, 2008 | 09:44 PM
AnotherSI's Avatar
if your going to be replacing the sensor just cut the top off so its just the hex in the bug. then you can put a shallow 7/8 on it.
itsrooster
15
Aug 24, 2013 04:15 PM
kelviiv
Jul 9, 2008 10:53 PM
Tigfab
Welding / Fabrication
Jul 17, 2006 06:43 PM
AThiker
Nov 27, 2003 05:42 PM
99ls
May 21, 2003 09:17 PM
