vtec pressure valve? code 22
Old Apr 30, 2008 | 05:24 AM
jasony0630's Avatar
Default vtec pressure valve? code 22
well i got a cel today....
i was at wot and my rpms didnt seem to climb as fast as usual in the high rpm range (from about 6k to 8k)
and i pulled a code 22, which is my vtec pressure valve...
what am i supposed to do now??
and whats the fix??
thanks a lot.
Old Apr 30, 2008 | 06:36 AM
jasony0630's Avatar
bump!
Old Apr 30, 2008 | 06:49 AM
cachase1's Avatar
Default Re: (jasony0630)
Try resetting the ECU first to see if the light comes back. If it does, check it to make sure it is the same code, you might have to replace the valve if it is. Sometimes, in the Prelude, I got weird VTEC codes that only happened once or twice. It seems like after I boosted it, those codes stopped happening and I just got ATTS codes.
Chris Chase
'02 Accord LX
'96 del Sol S
Old Apr 30, 2008 | 06:54 AM
jasony0630's Avatar
ahh ok.
well I may just add...
after I turned off the car for like 20 minutes and drove back, the light never came back on...I even took it to vtec engagement rpm and it seemed fine...
should I be worried?
Old Apr 30, 2008 | 07:01 AM
cachase1's Avatar
That would depend on your modifications. If you have none, there might be a problem. If you have things like an intake and exhaust, I wouldn't worry about it too much. The cars are designed to run on factory parts. When you change things like the way the engine breathes, it'll sometimes throw a code at you.
Chris Chase
'02 Accord LX
'96 del Sol S
Old Apr 30, 2008 | 07:20 AM
jasony0630's Avatar
well....according to other peeps, my car isn't very "stock"
it used to be a d16y8 obd2 automatic, and got converted to obd1 + 5speed swap + B16A3 swap + T3/T4 .50 trim turbo + 2.5" full exhaust + intercooler + charge pipes + 440cc injectors + 7psi.
Should I still be worried?
Old Apr 30, 2008 | 07:28 AM
cachase1's Avatar
Ok, so it's not exactly stock. I wouldn't worry about it at all unless the same code keeps coming back. If you didn't reset your ECU, the code will still be stored until it is removed. If you get another check engine light and check it, that one will still be there, I would still clear it to make sure it's not the same one next time.
Chris Chase
'02 Accord LX
'96 del Sol S
Old Apr 30, 2008 | 07:36 AM
jasony0630's Avatar
alright, thanks for all your help man.
Old Apr 30, 2008 | 08:29 AM
Panda Eg6's Avatar
Im guessing you swapped a jdm motor in? and if so you need to splice the vtec pressure valve with the vtec solinoid wire from the ecu
Old Apr 30, 2008 | 07:33 PM
dr.garagetuner's Avatar
well thats the vtec pressure switch my b16 threw this code and i just swapped out the pressure switch with a spare one and it fixed it.
Old Apr 30, 2008 | 11:23 PM
jasony0630's Avatar
oh...
i've had this swap in for about 3 months already, and it threw the code today...then it went away after i started it back up.
thanks though!
Old May 1, 2008 | 07:41 AM
Panda Eg6's Avatar
Yea, the code will only come on when you are in vtec for a certain amount of time. Its because the USDM ecu is looking for the vtec pressure valve that isnt even on the JDM motor therefore throwing a code. You can turn the car off and back on and it will go away, but it will not solve the problem.
usdmEHboy
Apr 14, 2007 08:23 AM
tachyteg
Aug 29, 2005 09:20 PM
AllMotorB
Jul 1, 2005 08:22 PM
davejj40
Aug 30, 2004 01:29 PM
