bogging problem?
Old Apr 30, 2008 | 04:24 AM
TattoonistInk's Avatar
Default bogging problem?
sup yall... i have a 1992 hatchback with a JDM crate in it.....ive had the car for a lil while now and it just started last nite going up a hill....is this the fuel pump???? if i take off 1st and 2nd gear are great!....but then when i shift into 3rd gear it starts bogging down....it only does it sometimes tho.....i noticed it more going up a small hill i realy hope this isnt the tranny...is so im [freak]ed....help????
oh....and i cleaned the motor last nite....but it didnt do this untill i was driving it for like 1 hour....u think i might have got moisture in one of the plugs?
Modified by TattoonistInk at 5:32 AM 4/30/2008
Old Apr 30, 2008 | 04:57 AM
Default Re: bogging problem? (TattoonistInk)
anyone out there????? i need help im sittin here staring at my car.....i do not understand the problem....i need help anyone?!?!
Old Apr 30, 2008 | 05:30 AM
23 views and not a single answer.....wow ......thanks guys
Old Apr 30, 2008 | 06:21 AM
db8SI's Avatar
wat fuel ... check timing .... could be a number of Things .. low oil just check that everything is correct
Old Apr 30, 2008 | 06:27 AM
Default Re: bogging problem? (db8SI)
low oil would cause this? ive checkd the oil and blew out all the plugs and connectors...it idols fine! i had it parked kinda at a downhill angle...mabie there is trash in the fuel cell and it creept its way up into the filter....thus cloging it? ..oh i use regular unleaded fuel......ive seen some threads on here about the motor bogging down....but it dont do it untill i get in 3rd gear runnin about 40krpm
Old Apr 30, 2008 | 06:31 AM
db8SI's Avatar
to be honest im not to sure wat the problem mite be ... maybe just wait a few more hours for replys from others they not online 24/7 like me
Old Apr 30, 2008 | 07:15 AM
is it normal for the headers to get extremely hot just after initial start-up?!?! well....its not bogging down anymore but my 2 cooler fans arent comeing on and i think that its making my headers heat up lots.....i dunno the brand of headers i got....but its drives fine now.....mabie i had moisture in one of the connectors i dunno...... but the car has never ran hot....nor did it just then....i ran it up the road and no bog......???
Old Apr 30, 2008 | 07:33 AM
dorkjoey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TattoonistInk &raquo;</TD></TR><TR><TD CLASS="quote">is it normal for the headers to get extremely hot just after initial start-up?!?! well....its not bogging down anymore but my 2 cooler fans arent comeing on and i think that its making my headers heat up lots.....i dunno the brand of headers i got....but its drives fine now.....mabie i had moisture in one of the connectors i dunno...... but the car has never ran hot....nor did it just then....i ran it up the road and no bog......???</TD></TR></TABLE>
does ur fan come on at all?
Old Apr 30, 2008 | 07:48 AM
biggdogg's Avatar
Default Re: bogging problem? (dorkjoey)
ur car is mad at you for puting those tails on it.
Old Apr 30, 2008 | 09:27 AM
Spoonsinglecam's Avatar
my car had tha same problem..mines were the spark plug wires were gone bad..and they were the expensive kind...1st chek tha oil first make sure its at right level and color. den check the spark plugs and spark plug wires...chek the timing and if its neither the problem.. it can be a hole or leak in the exhaust.. if not that then its the tranny.
Old Apr 30, 2008 | 09:28 AM
shizkabob3421's Avatar
Default Re: bogging problem? (biggdogg)
maybe you should downshift going up hills maybe that will help
Old Apr 30, 2008 | 11:36 AM
db8SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggdogg &raquo;</TD></TR><TR><TD CLASS="quote">ur car is mad at you for puting those tails on it. </TD></TR></TABLE>
maybe you should just help him out instead of posting sH** up about clear lights
Old Apr 30, 2008 | 11:53 AM
biggdogg's Avatar
my bad, well it seems the prob has fixed itself just needed to dry out a lil. u need to check ur relays for the fans and the temp switches. i`m sure its gonna be one of those. if not just hard wire it to a switch and u can turn it on urself.
Aug 10, 2009 01:57 PM
Barney Stinson
Honda Civic (2006 - 2015)
Apr 30, 2008 07:14 AM
integraboi1010
Mar 5, 2007 09:14 AM
SivikHatch
Jan 21, 2004 01:35 PM
