BrianCrower stg III NA cams, too big for boost?
i have a built b20vtec with BrianCrower stage III NA cams, i was wondering if these cams are too large for a boosted setup, i plan to run as high as 20psi on race gas with a gt35r.
here is everything i have:
b20 block with 10:0 probe forged pistons and eagle rods
ported pr3 head with briancrower stage III NA cams
edelbrock victor X intake manifold
AEM EMS for tuning.
if anybody is wondering why i want to do this it's cause this car was originally built for na but im feelnig the itch and am hoping i dont have to change any parts.
AEM EMS for tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">where are the specs </TD></TR></TABLE>
Dur at .050 is 260/254 lift is 12.60 12.60
taken from : http://www.briancrower.com/mak...shtml
not sure if thats what your asking for.
in for results on an interesting combo...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">they seem rather small in comparison to what others are running
did you check the BC website, they list like 3 numbers for everything, im not sure if i posted the right info, who are these others and what are they running? i know tony1 was running pro1's, i didnt know anybody else had large na cams for there boosted set up...
pro1's are:
Intake:
264°/12.6 @ 1mm / 0.000” lash
Exhaust:
264°/11.9 @ 1mm / 0.000” lash
but it seems skunk2 measures them a different way?
pro1's are:
Intake:
Exhaust:
Video of Chris Delgado (bugermass) tuning a bone stock LS with big all motor cams + sc61 making 407hp on a super conservative tune:
http://www.youtube.com/watch?v=DpXsTOe8upM
HT thread:
https://honda-tech.com/zerothread/2220690
HT thread:
IMO those cams seem like they'd be GREAT for boost.......not super crazy duration and with high lift......which will allow plenty of flow, and the duration doesn't lend itself to too much overlap, which can be tuned of course with cam gears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
pro1's are:
Intake:
Exhaust:
but it seems skunk2 measures them a different way? </TD></TR></TABLE>
I think these are measurements @ 1mm degree of lift.
i.e.:
Measured @ 1mm of lift
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-243 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Measured @ 0mm of lift
Int-278 dur. / 11.5mm lift
Exh-280 dur. / 10.5mm lift
taken from:http://www.jdmcivic.com/forums...18100
pro1's are:
Intake:
Exhaust:
i.e.:
I dont think so, I heard of people using todas cams and making good power I dont know how true that is but if so Im going to go out and get a set, its funny how all motor cams make great power on a boosted setup because some tuners used to say that they were bad for your turbo setup.
it just takes intelligent tuning to eliminate overlap.
I do like cams with higher lift and moderate duration, where you can still get good duration without having to tune a lot of it out to prevent overlap.
