wont start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danziver »</TD></TR><TR><TD CLASS="quote">If all its doing is clicking then you should check you battery first.</TD></TR></TABLE>
^^^most deffenitly agreed^^^^ its gunna be your battery i garuntee it....
I have the same problem i thought it was the fuel pump so i got a new one.. i heard the fuel pump once and never heard it again but even with the new fuel pump when i try to start my car all i hear is a clicking... and we tried to jump start it and thats when it goes over but wont start my spark plug wires are in the right fireing position. and when we tried to push start the car it turns on for a 2 sec or so and then it shuts off what can i do or what can i check to see whats the problem.. I need help fast
99.8% Chance it's your battery. Try recharging or replace the battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1chst3r »</TD></TR><TR><TD CLASS="quote">I have the same problem i thought it was the fuel pump so i got a new one.. i heard the fuel pump once and never heard it again but even with the new fuel pump when i try to start my car all i hear is a clicking... and we tried to jump start it and thats when it goes over but wont start my spark plug wires are in the right fireing position. and when we tried to push start the car it turns on for a 2 sec or so and then it shuts off what can i do or what can i check to see whats the problem.. I need help fast
Could be your main relay ''clicking''.. Can you hear the noise coming from a specific spot? maybe down near the hood release latch.. ? Also if you can't hear the fuel pump prime.. I'm almost positive it's your main relay.
</TD></TR></TABLE>Could be your main relay ''clicking''.. Can you hear the noise coming from a specific spot? maybe down near the hood release latch.. ? Also if you can't hear the fuel pump prime.. I'm almost positive it's your main relay.
i just heard it the first time when i installed it... after that i couldnt hear it anymore... and when im about to start the car all i hear is a noise and sounds like its getting electicity but other than that it goes over when i jump start it only. and when i dont all i hear is a click click click. and now i cant even hear my fuel pump
and i just got it today but where is the main relay located on a 94 ls teggy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">99.8% Chance it's your battery. Try recharging or replace the battery.
You should of made your own thread.. So this one isn't hijacked..
So the car starts when you jump it off or push start it?
Check your battery.. try recharging it or replace it.. also check grounds..check the starter signal wire on the starter and the ground on the starter.
sorry for coming into this thread but i just need some help well it dont start at all when i jump start it all i hear is that it wants to start but it just wont..and when i push start it it starts for a sec or two and then i step on the gas but it keeps on shutting down.... and i just got new spark plugs and wires, and the fuel pump since i couldnt hear it. and when i try to start the car without jump starting it all i hear is a click and wont even go over. but yeah bro ur helping me alot bc for some reason i did think it was the main relay or the fuel pump (not sure if they are the same) but the car had just been worked for the timeing and the water pump should i just check the main relay and how do i know if its bad? and where is it located
thanks bro ur helping me alot here :D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1chst3r »</TD></TR><TR><TD CLASS="quote">sorry for coming into this thread but i just need some help well it dont start at all when i jump start it all i hear is that it wants to start but it just wont..and when i push start it it starts for a sec or two and then i step on the gas but it keeps on shutting down.... and i just got new spark plugs and wires, and the fuel pump since i couldnt hear it. and when i try to start the car without jump starting it all i hear is a click and wont even go over. but yeah bro ur helping me alot bc for some reason i did think it was the main relay or the fuel pump (not sure if they are the same) but the car had just been worked for the timeing and the water pump should i just check the main relay and how do i know if its bad? and where is it located
thanks bro ur helping me alot here :D</TD></TR></TABLE>
Assuming this is on a 1994-2001 integra
Go to this page
https://honda-tech.com/zero...ge=12
And scroll down on the page.. There is a write up and how to replace the pgm fi relay.
Now that you know where the relay is.. try to start the car and see if you hear the click coming from that relay or it making any noise.. try tapping on it and see if it will start..
In summer time hondas/acuras are notorious for the main relays to go out because the joints on the relay get dry and cracked from the age, time,etc.
You can fix the relay by removing it, and pulling the cover and re soldiering the joints... The writeup shows you everything to do..
thanks bro ur helping me alot here :D</TD></TR></TABLE>Assuming this is on a 1994-2001 integra
Go to this page
Thanks bro now i know where it is now the second step is finding one im sorry but such a noob with this since i got the car for 500 i couldnt let go and plus i like the teggy :X and if i change that and it still wont start what could be my next option well let me start another thread :D since i dont want to hijack this one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_zooooms »</TD></TR><TR><TD CLASS="quote">ok thanks for all the help i got it running now</TD></TR></TABLE>
what was wrong with it?
muhaMan
Jul 3, 2007 10:01 PM
