Carnk seal
Old Apr 29, 2008 | 09:16 PM
dc96819's Avatar
Default Carnk seal
96 civiv.Can the crank seal be replaced or i need to get the lower timing belt cover
Old Apr 29, 2008 | 09:22 PM
2wheelhunter's Avatar
Default Re: Carnk seal (dc96819)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc96819 &raquo;</TD></TR><TR><TD CLASS="quote">96 civiv.Can the crank seal be replaced or i need to get the lower timing belt cover</TD></TR></TABLE>
that makes no sense..
what is the problem? is oil leaking through the crank seal into the timing belt?
Old Apr 29, 2008 | 10:03 PM
dc96819's Avatar
Default Re: Carnk seal (2wheelhunter)
Planning on replacing the timing belt and at the same time fixing the oil leak thats all over the driveway.Not sure exactly where its coming from yet.
Old Apr 30, 2008 | 06:58 AM
geebs's Avatar
well while you have the timing belt covers off if there is oil leaking from the oil pump seal you can replace it.. its like a $3 seal and most honda's have them in stock.
skhell
Jul 24, 2016 09:14 PM
unidennew
Nov 17, 2007 11:53 AM
soon2bdropped
Apr 7, 2007 05:16 PM
VTgringo
Aug 11, 2004 03:47 PM
trooper0641
14
May 4, 2004 09:41 PM
