No more puddles in your spare tire area [fix that hatch leak]
Old Apr 29, 2008 | 07:50 PM
acmoc's Avatar
Default No more puddles in your spare tire area [fix that hatch leak]
OK, so I know allot of us have leaks in our EF's, mainly in the hatch, I've been struggling with mine too. But I got one source of my leaks done. I'm gonna show you what one could possibly be. I found this while replacing my tail light gaskets and I haven't seen this come up as a fix for it.
there are other things that could be leaking, here are some other things readers found:
weather stripping
bad taillight gaskets
rear washer fluid nozzle
area where hatch meets needs sealant
window gaskets
if none of these worked for you, try this hopefully it'll fix it.
Okay, as I mentioned before, I found this while replacing my tailight gaskets. So step one would be to remove your side tailights [IMG][/IMG] http://www.flickr.com/photos/10774352@N02/2453789466/now step 2
their is like a drain hose I found their that routes water to the outside fenderwell, it connects to an exit hose in their somewhere and might not be connected (my problem) or clogged and backing up. draining the water to your spare tire area [IMG][/IMG] http://www.flickr.com/photos/10774352@N02/2453789484/ [IMG][/IMG] http://www.flickr.com/photos/10774352@N02/2453789508/ [IMG][/IMG] http://www.flickr.com/photos/10774352@N02/2453789534/the little black tip comes off, remove it and unclog it, put you hand in the car and feel around for the meeting hose, it'll go in about 2 inches. I might remove the black tip altogether if it gets clogged again.
now replace your tailights and your done.
If you want, sit in the hatch while someone sprays water on your car, look for the leak, you might just need a little dab of sealant somewhere.
Okay, my remaining issue is that whenever I turn on my rear washer nozzle I get a leak from my headliner, anyone know how to fix this. I'd really appreciate it
there's one on each side of the car, so do both
Old Apr 29, 2008 | 08:00 PM
UfoTofU's Avatar
Default Re: No more puddles in your spare tire area [fix that hatch leak] (acmoc)
The leak from the headliner when you spray the rear window is probably a bad plastic connector.
If you take off the plastic surrounding your dome light you should see it. It will run towards the driver's side of the car.
It joins two pieces of hose together and has been there since the car was made. The years of heating up and cooling down have probably taken their toll on it.
Check a local auto parts store for a similar connector.
Old Apr 29, 2008 | 08:09 PM
acmoc's Avatar
Default Re: No more puddles in your spare tire area [fix that hatch leak] (UfoTofU)
Thanks, how do you get that liner off... W/o Breaking anything?
Modified by acmoc at 9:44 PM 4/29/2008
Old Apr 30, 2008 | 09:26 AM
Thundercat's Avatar
bumo for good info ...i need to fix my leak
Old Apr 30, 2008 | 08:07 PM
JRZ88DX's Avatar
Default Re: No more puddles in your spare tire area [fix that hatch leak] (Thundercat)
good write up
chase7687
10
Jun 13, 2011 12:46 PM
CR91X
12
Jun 24, 2007 07:55 AM
GsrTurboCRX88
Dec 13, 2006 01:23 PM
spincycle
Nov 10, 2005 07:57 AM
sxecustoms
May 31, 2003 02:30 PM
