Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Steering Wheel is angled when going straight....02 Civic 4DR
Old Apr 29, 2008 | 06:57 PM
EL-Driver's Avatar
Default Steering Wheel is angled when going straight....02 Civic 4DR
I just aquired a 02 Civic 4DR EX...1.7 SOHC VTEC...
A little bit of mods, bore out TB, stock height and 205/55 tires on SIR's, 04 rear bumper
got for a real good deal but needs some TLC....
One of things on the list is the steering wheel, as I am driving the car in a straight direction...the steering wheel's position is at an angle, all though the owner did get an alignment before selling it to me...
None the less what could be causing this? where do I start looking? could this be the steering rack is toast or could it be something else?
I also plan on lowering this (2 inches front and rear), this gen civic is all new to me, and they say I should use EP3 tie rods...is there a specific year or are all the same?
But first things first, gotta fix the steering wheel...so what would you suggest is doing this?
Thank you in advance for your help
Old Apr 29, 2008 | 07:12 PM
smk's Avatar
smk
The alignment shop should have fixed when the previous owner went for one.
Just wait until you lower your car again, and specifically ask the alignment shop to straighten out your steering wheel.
Old Apr 29, 2008 | 07:51 PM
EL-Driver's Avatar
Default Re: (smk)
I will take that into consideration then...
curious are there are any signs in which too look for if my steering rack is toast?
Old Apr 29, 2008 | 08:06 PM
Synapz's Avatar
Default Re: (EL-Driver)
if the steering rack is toast, it would definately make a lot of sounds when you're turning.
check your power steering fluid
you can also look at your steering rack, check the boots for any leakage, if there's nothing, i wouldn't worry about it too much, as i think your problem should be solved with an alignment
Old Apr 30, 2008 | 06:36 AM
Harlowe's Avatar
Function>Fashion
Has the car been in an accident? Mine did that when I bent a front lower control arm..
Old Apr 30, 2008 | 11:16 AM
Curiouz_G's Avatar
sometimes it just does it. my cars suspension was perfectly fine but even after an alignment on BRAND NEW Hankook RS2's, it still required me to pull it to 1 side in order to get it to go straight.
Old Apr 30, 2008 | 11:39 AM
Synapz's Avatar
Default Re: (Curiouz_G)
yeah that's what sucks, you should do an alignment after you change your tire/wheel size
Old Apr 30, 2008 | 11:47 AM
Curiouz_G's Avatar
i just mentioned that i did. it still pulls.
Old Apr 30, 2008 | 02:32 PM
EL-Driver's Avatar
Default Re: (Harlowe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harlowe &raquo;</TD></TR><TR><TD CLASS="quote">Has the car been in an accident? Mine did that when I bent a front lower control arm..</TD></TR></TABLE>
What happened after?
Actually I asked the owner today, and found out that the front lower control arm was replaced...
and hence why the alignment was done...
so my question is it still fixable or should I shell out the dough for a steering rack?
Or can an alignment shop still be able to fix the steering wheel?
I do plan to replace the tie rods, with Ep3 ones, once I figure out which ones are compatable w/ my sedan
civic4life8045
18
Jun 5, 2013 09:10 AM
vtechtone
Suspension & Brakes
Jan 5, 2010 12:44 PM
huckaboo
Suspension & Brakes
Apr 7, 2009 02:20 PM
Nocturnal
Apr 18, 2006 06:25 PM
