HELP!!!!! Car won't cut off with the switch
I swapped from DPFI to MPFI and from obd0 to obd1 and now when i start the car and try to cut if off with the switch, the switch acts like I havn't even turned it to the off position.... the switch did turn it off once or twice but that was as soon as I started the car and also the car has a code 9 and code 16 if that has anything to do with it. PLEASE.........HELP!!!!!!!
Replace your ignition switch
it comes off with 2 Screws.
you can unplug it from the Fuse Block, or just cut and wire up the new one.
MAKE SURE, if you get one from a junk yards its from another 91 series
IE' Crx,Hatch.
Modified by hammergunner at 3:01 PM 5/2/2008
IE' Crx,Hatch.
